1969 L88 Radiator Bracket
Old Oct 17, 2018 | 11:24 PM
marky mark's Avatar
marky mark
Default 1969 L88 Radiator Bracket
Zip is showing one top center bracket for the (aluminum I suppose) radiator for the L88 engine (part #M-260).
Is this correct, meaning is there only the one center bracket instead of one on each end of the top of the other big block radiators?
Cheers,
Mark
Old Oct 18, 2018 | 06:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
IIRC, that might be correct. Have you checked the AIM?
Old Oct 18, 2018 | 07:56 AM
gbvette62's Avatar
gbvette62
The L-88 used the same aluminum radiator as the 65 396. The design of the 65 396 and L-88 radiator, is similar to the 63-72 aluminum small block radiator. Unlike the copper big block radiators that sit in 2 saddles with rectangular cushions, and have 2 more saddles and cushions on top, the L-88 radiator has 2 pins on the bottom that get small round cushions on them, and the a single bracket on top, that gets an inverted "U" shaped cushion under it.
The 396/L-88 is a great radiator. It's so good that when Chevrolet first started racing the Z/28 in Trans Am, they were having constant over heating issues, and the only way they were able to solve them, was by using the L-88 radiator in the racing Z/28's.
Old Oct 18, 2018 | 08:45 AM
marky mark's Avatar
marky mark
Thanks Mike that's good advice that I sometimes forget to do.
My AIM isn't at the house but I'll look for the diagram later on today.
Old Oct 18, 2018 | 08:55 AM
marky mark's Avatar
marky mark
Thanks GBvette. What I've got is a Dewitts Aluminum radiator (their version of the L-88 I think it was llisted as). I have a bunch of the cushions and brackets from Zip for the 'aluminum radiator' so I will see. The two lower brackets left from the previous radiator (this car was originally an L-36 427/390) so those brackets are still in place.
Hopefully they are not welded to the radiator support frame. I'll be able to look at the car and the AIM later today.
Cheers!
Mark
Old Oct 18, 2018 | 09:05 AM
marky mark's Avatar
marky mark
I just saw the old zip diagram on the radiator box and it does show the two round lower supports as well as the other two lower brackets. Then the center support on top with another shroud support.
So I will hope to see two holes in the radiator support and should be ok if so.
Old Oct 19, 2018 | 01:40 AM
gbvette62's Avatar
gbvette62
Cheers!
Mark
To use the L-88 radiator, you need an L-88 core support. The support used for the regular copper big block radiator, is completely different than the support used with the L-88 radiator. The lower supports needed for the L-88 radiator are not on regular big block supports, and since the copper radiator is much wider, the opening in the support is much wider than the L-88 radiator itself. The 67 and 68 L-88 supports are available as repro's, but I don't know that the 69 is.
Old Oct 19, 2018 | 09:15 AM
marky mark's Avatar
marky mark
gbvette62, thank you for that good info. I'll look at the support and radiator early next week see what I have. That would be ashame to need a diff radiator (or support) at this point, but wont be the first part I've bought that didn't get used. Ouch...
Old Oct 30, 2018 | 04:25 PM
marky mark's Avatar
marky mark
Follow up: The Dewiit's aluminum L-88 style radiator does not come with the two round supports. Nor does it have a locator for the center bracket.
So, it should fit in the existing 'C' supports on both bottom and top. I will know in the near future, lol.
To 1969 L88 Radiator Bracket
