composite rear spring
Id like to get VBP since I dont want the rear to be raised up, is there a way to determine what brand the spring is? a lot of the websites just have prices and specs but dont state the brand name.
though I haven't tried all of the combinations.VB&P composite springs may still be available on eBay, or even on this Forum. That's where I got my 385 lb NOS unit (360 lb shortened one inch at the factory for a higher spring rate). With Bilstein Sports, it is not harsh at all, and kinda wish I had found a 420 lb spring instead. I just completed a rear-end rebuild with rebuilt trailing arms and heim-jointed strut rods. I have no idea what's in the front, but I need new shocks, and everything else up there.
You cannot equate a composite spring rate to a steel spring rate..they are not equivalent. The OEM 78 Sport steel spring rate was 292lbs and was MUCH stiffer and harsh.
Like you ^^^^, one day when I need a new composite (the one now is from 1986), I will probs go to a 420 composite since the rear is still a hair too soft by modern sports cars' standards...my 10 C6Z06, 12 Lexus IS350 F Sport, and 08 Chrysler 300 with a slightly modified Suspension including Bilsteins/Strut tower brace, and ultra High performance AS ZR tires are all MUCH stiffer than my 78 C3.....
They supplied all my suspension parts, are very knowledgeable and will give you good advise based on how you plan to use your car.
I still call them and ask for advice and they give it freely and haven't steered me wrong yet.
As a matter of fact just ordered a set of their tubular lower control arms for my 73.
The Van Steel spring, I've heard, is more curved. I'd call them and ask if I were in the market for another spring.
I've read through threads here and want to maintain the razor sharp handling. Everything I have read says the monospring makes it ride smoother, handle better and just makes it more fun. I want to play with it, maybe drag it, some autocross if I can ever get the time, but 99% of the time it will be a daily toy to make getting up in the morning a pleasure, and going home with a smile on my face because I get to drive my dream car again.
Unfortunately, the general consensus seems to be Bilstein Sport shocks for any monospring, and anything less than a 360lb spring sounds like mashed potatoes. One of the most recurring sentiments in this topic seems to be "I wish I had gotten the 420lb or stiffer spring." Corvette Central(my go-to) sells a full kit, but only go to 355. After reading on the forums the HD's were the best way to go for stock, I bought the set of those. I suppose I can send them back if I had to, but since I have the car on stands anyway, now is the time to get all this crap done.
Should I go with the 420(sourced from Corvette Mods) send the HD's back, swap for Sports, or keep the HD's and go with a 360? I live 5 miles back on a dirt road in the southwest, and i don't want to bottom out and hammer the bumpstops. It's a substantial investment, and I just don't want to have to buy everything twice because i didn't listen to the voices of experience.
I choose my routes, and can avoid bad roads for the most part. 385 lbs is too soft for the way I drive my 4-speed, and I have zero interest in drag racing (My engine mounts are bad, winter project, so I can't even launch the car if I wanted to). With the swaybar in the back, it will probably be okay, but I want to make sure the front is balanced and stiffened first (again, winter project), lest I end up looking like a Mustang leaving Cars and Coffee.
I'd suggest starting a new thread, as your application is very different than titanle's.
Do you have a rear 7/16 inch sway bar? If you do, then you have the gymkhana sport suspension with a 292lbs rear transverse rear spring. I doubt you do since you said the car rides soft now. The base suspension rear spring is 172 LBS which by sports cars standards is VERY SOFT, bordering on cadillac ride soft from the 70/80's.
If you do have a base suspension 80 C3 which 75% of the 80's were and not a gymkhana suspension C3 then you would want a 300lbs rear composite spring. If you have the sport suspension then the 360 spring.
The Bilstein HD's are fine with the 300 lbs spring but I use Sports in the rear only (360lbs Composite spring) of my 78 OEM equipped Gymkhana car with HD's in front with the sport front coil springs.
I would not advocate someone going to a 420 lbs rear spring without desiring serious sports car like handling for their C3..sounds like your car is more for cruising if you have the base suspension....The 77 and 80 suspensions are the same so if your 77 rode hard (gymkhana suspension) and your 80 is soft, then the 80 with the 172lbs rear spring is the reason although I must admit you say the 80 has "razor sharp" handling which is near impossible with the base suspension.....
So what do you have now?
Thanks for the replies!
Sorry typo,,,meant 360 not 460 ...Bilstein Sports in the rear with 360 composite
