Muncie 4 speed linkage too forward
Old Oct 27, 2018 | 01:42 AM
35035069c3's Avatar
35035069c3
Cruising
Default Muncie 4 speed linkage too forward
Hello All,
First the good news.. engine was rebuilt, started and broke in the cam today.
However.. After putting everything back together, specifically the transmission and shift linkage, I was assuming the linkage settings would all be the same since nothing was changed. When connecting the shift linkages to the transmission and crossmember, the shift arm now touches the center console bezel and will not stay in 1st and 3rd gear. I looked for some adjustments and see that the shift linkage housing/mount straddles the cross member, and there is no front to back adjustability. I suppose I could readjust the shift arms, however I’m baffled why they didn’t line up. Wondering if anyone has had this issue, and if it’s normal.
Thanks in advance
Old Oct 27, 2018 | 02:19 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
You should post some pics of the linkage to help with a diagnosis .What I did was get the shifter alignment tool to make sure that the shifter is in the right position ,then put the gear box in the neutral position and reconnect the linkages and was good to go.
Old Oct 27, 2018 | 07:56 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Maybe that short bolt that holds the shifter is in the wrong hole?
Old Oct 27, 2018 | 10:27 AM
Wee's Avatar
Wee
You may have to shim shifter mount.....There are bolts on top. See link below for a better explanation.
https://www.corvetteforum.com/forums...sole-hole.html
Brian
Old Oct 27, 2018 | 12:25 PM
MelWff's Avatar
MelWff
As suggested you can shim the mount or if you have dual sets of holes switch to the short shift set.
Old Oct 27, 2018 | 07:36 PM
35035069c3's Avatar
35035069c3
Cruising
Great advise everyone, thank you. Would there be a reason why the shifter won’t line up, just trying to understand what may have changed. The only item I changed was the motor mount -the OEM safety motor mount, but I can’t see how this would have changed anything. What I don’t want, is to allow binding that may have occurred during the re-installation, I did have one side of the car on jack stands, not an ideal level frame. I’m going to drive it up on four ramps, loosen the motor mounts and all of the transmission support and shift linkage to see if it settles. Sorry no pics, the shifter just hits the center console.
Old Oct 27, 2018 | 10:58 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you may have pu the linkage in the upper holes of the shift arms which gives it a longer throw. Use the lower holes that are closer to the attachment nut and the shifter throw will be shorter. Either that or the arms are in the wrong holes
Old Oct 28, 2018 | 07:49 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Check to see if your center console is loose and/or try adjusting it forward.
To Muncie 4 speed linkage too forward
