Lifter question
Old Oct 27, 2002 | 08:29 PM
brewvette's Avatar
brewvette
6th Gear
Default Lifter question
OK. I know this sounds elementary, but since I'm doing this for the first time....
I'm in the process of a cam/lifter swap on my 77. While I'm trying to pull the lifters out, they seem to get stuck about 1/2 way up. Am I missing something obvious? Is there a trick here to getting the lifters out?
Old Oct 27, 2002 | 08:48 PM
scottw's Avatar
scottw
Default Re: Lifter question (brewvette)
brewvette,
When I did mine a couple months ago once I got ahold of them they came right out. I had a couple hang up and I slowly twisted them out as I pulled them up. Beside that, not sure what else it could be.
Old Oct 27, 2002 | 09:08 PM
73 LS-4's Avatar
73 LS-4
Sometimes they'll build up a little varnish toward the top of the bore and they tend to stick there.
:cheers:
Pat Kunz
Old Oct 27, 2002 | 09:23 PM
Titanium Rat's Avatar
Titanium Rat
Default Re: Lifter question (73 LS-4)
use a good set of 6 in. vice grips to pull them out. :yesnod:
Old Oct 28, 2002 | 09:50 AM
Ybnormal's Avatar
Ybnormal
Brewvette,
Mine were the same way also when I replaced them this summer. They will come out, just takes some force like vice grips.
:smash:
YBNormal...drive a vette
www.angelfire.com/al/swhite7/engine.html
Old Oct 28, 2002 | 05:16 PM
HWY 9 - Z06's Avatar
HWY 9 - Z06
you can grab them with vice grips, but don't force them, if its not varnish, and they are mushroomed on the bottom, you could damage the lifter bore and cause yourself grief. it they wont come out through the valley, unfortunatley the only other way is out the bottom.
To Lifter question
