My Tach Zero'ed Out suddenly!
Old Oct 30, 2018 | 04:03 AM
NICE-7D3's Avatar
NICE-7D3
Default My Tach Zero'ed Out suddenly!
Had a fine cold start on a 40 degree morning and an rasy ride to work. While warming up on a 49 degree day to go to lunch after 4 hour cool down, after two easy pumps on accelerator pedal to release the choke some, my tach dropped to 0 and just quit. Any guesses to why or what I can check?
Last edited by NICE-7D3; Oct 30, 2018 at 04:30 AM. Reason: Adding photos and mispelling
Old Oct 30, 2018 | 06:33 AM
jim2527's Avatar
jim2527
Tach quite or the engine died? Tachs mechanical so...
1. Check connection at distributor
2. check connection at tach
3. Is inner cable broke? Disconnect at distributor ans spin by hand. Does tach needle move?
Old Oct 30, 2018 | 06:52 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I had mine snap for no good reason, just disconnect it at the distributer and twist it. You'll be able to tell if its snapped. You can buy just the interior cable but you will need to disconnect it at the tach to get the other end out. Its and easy solve but you need to check the length.
Old Oct 30, 2018 | 07:19 AM
Tonio's Avatar
Tonio
Mine did the same. Cable snapped. Easy $5 fix if you just buy a universal inner cable. Trim it to your length and slide it in.
The repop cables from many vendors are too long and are prone to premature failure.
Old Nov 1, 2018 | 11:35 PM
NICE-7D3's Avatar
NICE-7D3
Appreciate the reply. Just the tach quit, not the engine. I'm planning a look into this weekend.
Old Nov 1, 2018 | 11:39 PM
NICE-7D3's Avatar
NICE-7D3
I'll get into it this weekend. Suggestions as to where I can get the inner cable and what the price range might be?
Old Nov 1, 2018 | 11:50 PM
Its_hers's Avatar
Its_hers
Wish my tach issue was a cable. New dist shaft and driven gear is on the bench waiting to go in.
To My Tach Zero'ed Out suddenly!
