Water pump pulley bolts ?
Old Nov 2, 2018 | 04:10 PM
jpattt24's Avatar
jpattt24
Default Water pump pulley bolts ?
I have 1971 corvette 350 with a stock corvette short water pump. I want to eliminate the fan clutch. I need to no what size bolts I need to bolt the water pump pulley on with. I think there 5 1/6 24 fine thread but not sure. ...….thanks
Old Nov 2, 2018 | 04:57 PM
JoeMinnesota's Avatar
JoeMinnesota
I believe you are correct. My '70 has studs with lock washers and nuts, which are 5/16"-24 on the pump side, and coarse thread 5/16"-18 on the front-facing side where I attach the clutch hub. You should be able to use some short 5/16"-24 bolts.
