Seat Belts
Old Oct 28, 2002 | 02:02 AM
vett70's Avatar
vett70
Default Seat Belts
Restoring my '70 roadster a little at a time and had to pick my "bearings" up off the floor after I saw the $$ for factory correct replacements!! :bb
Does anybody know where I can get functionally correct aftermarket shoulder harnesses/lap belts. Seems there are plenty of generic lap replacements out there but none with shoulder harnesses. Ijust want ot be safe, that's all.
Old Oct 28, 2002 | 05:29 AM
1979toy's Avatar
1979toy
Default Re: Seat Belts (vett70)
Haven't done it myself but I understand that a late model F-Body rear seat belt will work although it is a bit shorter than original. Tunedport78 has a link to the conversion here; http://www.corvetteforum.net/c3/tune...8/index2.shtml
Also check the Corvette FAQ for information on having your belts reconditioned. This is the link; http://www.bokonon.net/corvettefaq/
[Modified by 1979toy, 3:32 AM 10/28/2002]
Old Oct 28, 2002 | 05:50 AM
vett70's Avatar
vett70
Default Re: Seat Belts (1979toy)
What is an "F-Body" ?
Old Oct 28, 2002 | 06:09 AM
Mystery Machine's Avatar
Mystery Machine
Camaro, I think. :confused:
Old Oct 28, 2002 | 06:14 AM
GaryS's Avatar
GaryS
Default Re: Seat Belts (Mystery Machine)
Correct.
How about doing a search for Corvette Salvage or something along those lines. I have used a guy in NY with fairly decent results on salvage items. Also, have you done a search on Ebay?
Gary
Old Oct 28, 2002 | 06:41 AM
1979toy's Avatar
1979toy
Camaro and Firebird
Old Oct 28, 2002 | 07:32 AM
Mystery Machine
I found this one... http://www.billygrahamscamaro.com/
Haven't ever used them but they seem like nice, family type folk :)
Old Oct 28, 2002 | 08:56 AM
USNEOD's Avatar
USNEOD
Take alook at this site for your seatbeltshttp://forums.corvetteforum.com/zeropost?cmd=reply&id=4453117
Old Oct 28, 2002 | 10:27 AM
R. Bruno's Avatar
R. Bruno
I replaced mine with a set of aftermarket shoulder harness that fit pretty nicely. Cost about $140 for the pair if I remember correctly and color match is very close. Send me an e-mail at rlbassinette@mindspring.com if you want the name and address of the vendor.
Old Oct 28, 2002 | 10:46 AM
JB's Avatar
JB
St. Jude Contributor
Default Re: Seat Belts (R. Bruno)
I used the Camaro belts in my '69, and it's an even easier fit in your '70 because they will bolt in to the factory anchors without modifying anything. Billy Graham's in the link above are great people to get the belts from--helpful, cheap (mine cost $48), and very quick shipping. The Camaro belts also show up on ebay from time to time, but don't go looking for the factory belts there because they always get bid up into the stratosphere.
JB
Old Oct 28, 2002 | 12:31 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Make sure you get "REAR SEATBELT, SHOULDER COMBINATION" not the front belts. They will come with the orginal Camaro/Firebird triangular metal guide plate with the belt thread through it. You'll have to cut the guide plate to get the belt out. It takes about 2 minutes with a hack saw or a cutoff wheel on your Dremel tool.
As BJ said, the 70 is easy to replace because all you have to do is bolt the Camaro reel on the top of your wheel well in the 70 factory location. If your 70 already has shoulder harnesses, then it is no problem. If it doesn't them you'll have to pull the carpet up from over the wheel wells. You'll see the bolt hole with a plastic plug screwed in it, just remove the plug and bolt the Camaro/Firebird reel down.
Your current Female/Latch should work with the belt so you won't have to change that out, if you want to replace that portion with the Camaro piece you'll find it is too short to reach down through the 70 sleeves, so you can extend them by getting a piece of steel strap to extend the length. I used a piece of stainless scrap about 1-1/4" wide by 7" long and 1/8" thick. I drilled a hole at each end of the strap, bolted one end to the belt portoin of the buckle, with a short grade 8 bolt with a lock nut. Then I threaded it through the sleeve and bolted the end of the metal strap to original mounting hole with the original mounting bolt.
The end of the belt that comes from the reel, should be threaded through your seat back guide and then bolted to seat belt mounting hole under the seat.
Good luck, it is a good upgrade and the belts work fantastically. The down side is that they only seen to come in Charcoal and Beige colors.
Old Oct 28, 2002 | 12:47 PM
Blackened 79's Avatar
Blackened 79
I HAD THE SAME EXPERIENCE WITH SEARCHING FOR ONE FOR MY '71.
WAS NOT GONNA PAY $375 TO GET A SET OF LAP BELTS. WOUND UP
SEARCHING FOR ABOUT A YEAR..FINALLY FOUND A SET AT CARLISLE
FOR $125...NOT MANY ORIGINALS AROUND.
Old Oct 28, 2002 | 02:06 PM
GR8T WYT's Avatar
GR8T WYT
Hi vett70,
I replaced the seat belts in my 77 with a set from Andover Auto, they specialize in seat belts. In fact I was so impressed with the fit and function that I did a product review on this forum under seatbelts. Their address is andoauto.com, this is the correct address, the one in my review I think is wrong. The only thing that I could not use was the stock retractor cover behind the seats, but not to worry, the andover retractors have their own covers and can hardly be seen anyway. And as a bonus there is no buckle dangling on the sill plate. Also the recievers will fit right into your stock sleeves. I believe the price is less than $70.00 a pair. Check it out. :D
Old Oct 28, 2002 | 02:10 PM
GR8T WYT's Avatar
GR8T WYT
Default Re: Seat Belts (GR8T WYT)
Sorry, make that product review catagory, Interior accessories, and then pick Andover seatbelt replacement.
Old Oct 28, 2002 | 05:37 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I'll concur on the Camaro belts. REAR belts out of a Camaro/Firebird from 1993 or newer bolt right into your '70 and work great. :yesnod:
Old Oct 31, 2002 | 10:46 PM
vett70's Avatar
vett70
Default Re: Seat Belts (ddecart)
Thanks for all the help guys!!
-Bill
To Seat Belts
