1971 Corvette LS5 AC
Old Nov 4, 2018 | 05:18 PM
thelal1's Avatar
thelal1
Default 1971 Corvette LS5 AC
Question, if AC is out of freon, will compressor still engage if ac switch is turned on or is there a pressure switch that keeps it from kicking on?
thelal
Old Nov 4, 2018 | 05:31 PM
Hammerhead Fred's Avatar
Hammerhead Fred
thelal
There should be a low pressure switch which prevents running w/o Freon.
Old Nov 4, 2018 | 06:31 PM
thelal1's Avatar
thelal1
Default AC compressor
So it wont respond to inside switch because of that low pressure switch.
Old Nov 4, 2018 | 07:22 PM
Hammerhead Fred
That could be one reason. There are other items (low outside temp switch, etc) that can prevent the A/C clutch from running.
You can test the clutch using a +12v jumper to be sure you're not chasing your tail.
Old Nov 4, 2018 | 07:48 PM
thelal1's Avatar
thelal1
Default 1971 AC Compressor
Old Jun 12, 2020 | 10:32 PM
FrankieD's Avatar
FrankieD
To 1971 Corvette LS5 AC
