new here please help me out
Old Oct 28, 2002 | 02:37 AM
stram9877's Avatar
stram9877
8th Gear
Default new here please help me out
I have read some of the posts but never actually posted before. I need help with something.
I have a '77 coupe with the auto trans. and i want to install tuned port injection. I have access to an '87 Iroc that would be the tpi donor car and it is complete. so here it is how hard is this swap what do i have to change or is there a book i can be referred to to do this. i also want to switch to the 700r4 trans. thanks for your help
Old Oct 28, 2002 | 05:12 AM
1979toy's Avatar
1979toy
Default Re: new here please help me out (stram9877)
I have not done either swap myself but one of the members that has was kind enough to set up a web site covering both of the swaps that you want to do and many other useful tips. Look up TunedPort78's site here; http://www.corvetteforum.net/c3/tune...8/index2.shtml
Old Oct 28, 2002 | 12:08 PM
jvm's Avatar
jvm
Good lucj on your swap. Fromn what I have heard most people go the other way and stay away from TPI. Unless your TPI is cheap or free think about a rebuild job with better heads, exhaust, and cam. .
Old Oct 28, 2002 | 12:23 PM
page62's Avatar
page62
What is your goal in doing the TPI swap? If it's fuel economy, you'd be AMAZED at how much the 700r4 tranny swap will improve your gas mileage! And there are other, less painful ways to improve engine performance...
Old Oct 29, 2002 | 02:38 AM
stram9877's Avatar
stram9877
8th Gear
Default Re: new here please help me out (page62)
Originally my goal was to just make the car more fun to drive. but you guys have given me quite a bit to think about i am reconsidering the tpi swap but i still want to go ahead with the 700r4.
thanks
Old Oct 29, 2002 | 06:26 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
isnt 87 the roller motor? id got for it! the hardest part of the engine swap would be the wiring harness. which wouldnt be too bad. the 700R4 is a fairly common swap into C3s... you should be able to find plenty of info on this. And TPI is good... CFI isnt. at least by todays standards. Also id play with heads and cam on the TPI motor... Try to get a good 350-400hp out of it if you have the money. might as well when its out of the car. :cheers:
Welcome to the forum!
Old Oct 29, 2002 | 06:08 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Unless you have to have a C3 with TPI, I wouldn't do it. I want TPI and a 4 speed auto as well.
So I'm buying a C4 (to go along with the C3).
Old Oct 29, 2002 | 08:47 PM
paso's Avatar
paso
Default Re: new here please help me out (joeveto)
Welcome to the forum. Please enter your data in the registry link below:)
To new here please help me out
