Headlamp Vacuum Help
Old Oct 28, 2002 | 11:30 AM
SLVRVET's Avatar
SLVRVET
Cruising
Default Headlamp Vacuum Help
I recently bought a '78 Corvette (my first). I was installing a new stereo and accidently disconnected both of the vacuum lines on the manual headlamp door switch. The headlamp doors opened. I reconnected both of the vacuum lines but the doors won't close. Does the system have to be reset or something.
Old Oct 28, 2002 | 11:38 AM
GDaina's Avatar
GDaina
Default Re: Headlamp Vacuum Help (William VanVeghten)
No, maybe u got the lines backward? Try reversing the vacuum lines on the switch
Old Oct 28, 2002 | 11:42 AM
Neo Fender's Avatar
Neo Fender
Default Re: Headlamp Vacuum Help (GDaina)
That is probably what happened. You'd think that if you cross the vacuum lines that the switch would work just the opposite, but it doesn't.
If that doesn't work, make sure you didn't pull a line loose elsewhere. From the auxillary switch, one line goes up to the headlight switch and the other goes to the vacuum source.
Old Oct 30, 2002 | 01:54 AM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Re: Headlamp Vacuum Help (Neo Fender)
This months Vette mag has a schematic drawing of where all the lines go. I suggest checking it out.
To Headlamp Vacuum Help
