Left Turn Signal?????
Old Oct 28, 2002 | 04:49 PM
Andrew's Avatar
Andrew
Default Left Turn Signal?????
My left turn signal does work, but when the lights are on, the running light does not work. I replaced the bulb several times, but cannot figure out why the running light will not stay on. Any thoughts or experience with this?
Old Oct 28, 2002 | 08:24 PM
Duke94's Avatar
Duke94
Default Re: Left Turn Signal????? (Andrew)
Which left light doesn't work, front or rear or both? Do the 4-way flashers work?
Old Oct 28, 2002 | 08:45 PM
Corvette Cowboy
Default Re: Left Turn Signal????? (Duke94)
You have a bad ground at one of the turn signal sockets.
Old Oct 29, 2002 | 10:06 AM
Andrew's Avatar
Andrew
Default Re: Left Turn Signal????? (Corvette Cowboy)
Duke94
The front left signal. The flashers do work along with the turn signal, just the running light does not work.
Corvette Cowboy
When you say socket, are you referring to the plastic piece that the bulb screws into? Can I get this from one of the Corvette suppliers?
:cheers:
[Modified by Andrew, 8:08 AM 10/29/2002]
Old Oct 29, 2002 | 09:05 PM
Duke94's Avatar
Duke94
Gotta be a bad ground. Run a tempoary wire from a good ground source (engine) and touch the ground lead on the socket.
To Left Turn Signal?????
