4 spd. reverse switchconnect/which wiring harness
Old Nov 20, 2018 | 09:09 AM
68 beginner's Avatar
68 beginner
Default 4 spd. reverse switchconnect/which wiring harness
68 vette 4spd. reverse switch
Old Nov 20, 2018 | 12:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I don't quite understand your question.... ?? But if you'd be a bit more detailed I'd be glad to give it a stab.
Willcox
Old Nov 20, 2018 | 12:05 PM
68 beginner
thanks...I finally found the wires by tracing backwards from turn signal flasher...someone had cut the wires and taped over them
Old Nov 20, 2018 | 12:08 PM
68 beginner
I figured out from my assy manual and wiring schematic from Dr. Rebuild that the conn. was on forward wiring harness and not the rear harness...thanks
Old Nov 20, 2018 | 07:11 PM
68 beginner
thanks for your help...solved that problemm...question...I installed a new a/c wire harness...the wires from the HEATER RESISTOR plug didn't go to the heater switch as shown in diagram...is the HEATER RESISTOR plug eliminated...68 vett with air...Malcolm
To 4 spd. reverse switchconnect/which wiring harness
