Stance leans to left
Old Nov 21, 2018 | 06:04 PM
lsintampa's Avatar
lsintampa
Default Stance leans to left
1975 coupe
I just finished replacing all front control arm bushings, tie rod ends, idler arm today. After I put the car down, there is a noticable slant to the left ( right side higher ). About 1/2 diff in the front and nearly an inch in the rear.
I'm fairly sure I got the springs seated correctly. If not, the right side may not be seated well. I'm sure about the left side, but I had a hard time with the right and I can't honestly say I recall making sure the spring was seated correctly. Hey at 68 and doing this on my own, I can't remember what I had for breakfast, so I just can't recall.
I don't know if the right spring not sitting in it's seat would result in the tilt, but I don't know what else might cause it.
I haven't moved the car at all, just put it down and bounced all four corners to see if it would settle... No dice.
please share your thoughts, ideas, suggestions.
Thanks,. Len
Old Nov 21, 2018 | 07:39 PM
derekderek's Avatar
derekderek
The rear is higher than the front and you didn't do anything in the rear? Drive it around a little.
Old Nov 21, 2018 | 08:15 PM
lsintampa's Avatar
lsintampa
To be clear - the right front is about 1/2 inch higher than the left front. The right rear is about 1" higher than the rear left.
Did nothing to the rear - correct.
I'm thinking that I have to check the right spring to make sure it is seated in the control arms correctly. Any easy way to do that - aside from dropping the control lower control arm down again?
Old Nov 22, 2018 | 05:39 AM
derekderek's Avatar
derekderek
You didn't touch the back yet the back is higher than the front. It's probably just the way it got jacked up and set back down. Have you moved the car yet? Drive it around.
Old Nov 22, 2018 | 07:52 AM
flyeri's Avatar
flyeri
I've been through this. If the right front is not seated correctly, raising that side, it will push the left rear down. I would drive it first before taking things back apart.
Old Nov 22, 2018 | 08:11 AM
HUSKEE73's Avatar
HUSKEE73
did you wait till car was back on the ground before you tightened control arms?also if you take a plastic garbage bag fold in half and put under each tire before putting back on ground it helps let the suspension relax.food for thought.
Old Nov 22, 2018 | 08:16 AM
lsintampa's Avatar
lsintampa
I haven't torqued them yet. I did bounce it on all four corners. Will need to wait to Monday to get back to it.
Will try the gb thing though.
Old Nov 22, 2018 | 08:33 AM
derekderek's Avatar
derekderek
just back up and go forward 10 feet each way and it'll settle back down where it belongs. You pick it up off the ground you put it back down the tires are in a different place. And then it's not going to relax and sit where it's supposed to.
Old Nov 22, 2018 | 12:31 PM
lsintampa's Avatar
lsintampa
Pulled the wheels off each side. Hard to tell, but it looks like the springs are seated correctly. Front end out of alignment for sure, but that will need to wait until I can get back to it next week.
I just now backed it out - about 15 feet or so and put it back in the garage. Still seems tilted to me. See photo:
Old Nov 23, 2018 | 10:32 AM
Tampa Jerry's Avatar
Tampa Jerry
Sounds like you did not index the front springs correctly. The spring is indexed to the top of the pocket in the frame. The end of the spring must be within 3/8" of the inspection hole in the frame. I put blue tape on the spring so I can see it through the top. You can also drop a 1/4-20 long bolt in the hole and move the spring in place until it just touches the bolt. Once together, remove the bolt. That should do it. Jerry
Old Nov 23, 2018 | 11:01 AM
lsintampa's Avatar
lsintampa
Thanks Jerry. If I understand you correctly, there is some adjustments that can be made on the springs to raise or lower the sides. IE it both springs are the same, indexing them to the inspection hole differently would result in one side being higher than the other.
Old Nov 23, 2018 | 11:24 AM
Tampa Jerry
Default Springs
You are correct. Some people use the lower A arm for indexing. This is incorrect. You must use the top of the frame pocket as your guide. Jerry
Old Nov 24, 2018 | 08:34 PM
derekderek's Avatar
derekderek
also, don't eyeball the height. Get a tape measure and measure from the top of the wheel well opening to the ground on all four wheels and compare them front to back and side to side. Also double check that the ground you're parked on is level.
Old Nov 25, 2018 | 12:39 AM
bazza77's Avatar
bazza77
you can see the end of the silver painted spring sitting halfway across the hole up near the shock. This is the left side. if the spring is not in correctly it definitely will have an effect on the car ride height.
Old Nov 25, 2018 | 08:19 AM
derekderek's Avatar
derekderek
also, don't trust your eyes. Take a tape measure and measure from the inside of the top of the wheel well Arch to the ground and compare the measurement both sides front and rear. if the ground is a little off level, the car will look crooked cuz it's sitting level on the crooked ground.
Old Nov 25, 2018 | 10:49 AM
Big2Bird's Avatar
Big2Bird
I agree. Rebuilt suspensions are always off until they settle. One side may be stiffer than the other. Drive it 20 miles and check again. Speed bumps help, but not too fast.
Old Nov 25, 2018 | 01:47 PM
lsintampa's Avatar
lsintampa
I'm not dropping the control arms again right now. I pulled off both wheels and looked at where the lower ends of the springs sit in the lower control arm and they are right at the stop in the lower arm. As far as the top, if I look at both peek holes I can see the spring on both sides. I don't see the edge of the top end of the spring through the hole, but I can see the spring and they both seem to be the same depth from the peek hole.
That said, I think driving it about for a while will settle things in a bit. Should I torque the control arm bushing bolts before or after driving it?
Also, I read somewhere about the upper control arm shims and that they also can change front ride height.. I bagged each set (left / right - front / rear) when I removed them and put them back in the same spots. Does anyone know how to adjust those shims???
To Stance leans to left
Old Nov 25, 2018 | 01:50 PM
lsintampa's Avatar
lsintampa
So let me ask this stupid question. While driving about, is it possible for those springs to realign themselves in their seats (IE - can they possibly rotate)?
Old Nov 25, 2018 | 02:55 PM
Tampa Jerry
I don't see how that is possible. The springs are under so much tension that they will not move once the spindle assembly is connected. Where in Florida are you located? Jerry
Old Nov 25, 2018 | 03:13 PM
sambrand's Avatar
sambrand
erm, don't try to drive around above 15-20 mph if your suspension is not torqued, as op said theres so much tension involved and adding the extra kinetic energy at highway speeds can cause all sorts of nasty surprises.
