Adjusting Shifter Linkage
Old Nov 25, 2018 | 04:20 PM
Lark327's Avatar
Lark327
Default Adjusting Shifter Linkage
72 350, 4 speed with stock shifter. I've seen the adjustment procedure, but without lifting the car to see underneath, I can't tell if the adjustment can be made from underneath or if I have to remove the shifter console, or both. Any help will be appreciated. Thanks.
Old Nov 25, 2018 | 04:22 PM
ddawson's Avatar
ddawson
I do it from under the car.
Old Nov 25, 2018 | 09:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The adjustment is made from under the car with the shifter lock in place and the linkage installed per the PDF below.
http://repairs.willcoxcorvette.com/w...er-linkage.pdf
You'll also need a gate lock that you can buy or fabricate per the picture below.... but without the linkage installed in the car you can't adjust it.
Old Nov 26, 2018 | 09:32 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Follow Willcoxs instructions, its pretty easy. While your under there check all the shifter and transmission bolts to make sure something didnt come loose. Theres a few things that could affect a shifting change
Old Nov 27, 2018 | 12:05 AM
theandies's Avatar
theandies
If your transmission levers have two holes then insert the alignment tool Wilcox posted and adjust your linkage to the holes in the lower part of the levers. This is the short throw setting and makes a world of difference if you want short throw.
Old Nov 27, 2018 | 11:41 AM
0Willcox Corvette
Former Vendor
Originally Posted by theandies
If your transmission levers have two holes then insert the alignment tool Willcoxcorvette.com posted and adjust your linkage to the holes in the lower part of the levers. This is the short throw setting and makes a world of difference if you want short throw.
The long throw holes are a bummer... short in this case is a smoother shift to me.
Willcox
To Adjusting Shifter Linkage
