Monospring bushing/shims
Old Dec 4, 2018 | 03:30 PM
gabesaad10's Avatar
gabesaad10
Default Monospring bushing/shims
I have a mono spring that I bought off a friend for my 77 but I don’t have the center bushing/shim portion, and I was looking everywhere online for them and I can’t find it, does anyone know where to find it or if anyone has it?
Old Dec 4, 2018 | 05:23 PM
MelWff's Avatar
MelWff
there is no manufacturers label on the spring?
Old Dec 4, 2018 | 08:54 PM
Cool95vette's Avatar
Cool95vette
Vansteel carries parts for composite springs. They may have what you need.
Old Dec 4, 2018 | 10:56 PM
gabesaad10's Avatar
gabesaad10
Ive looked everyone and still can’t find it there isn’t a label on it and I checked van steel and I can’t find one
Old Dec 5, 2018 | 04:40 AM
bazza77's Avatar
bazza77
does it have the same shape as this type , they are the same make but different weight ratings .Also forget the heat wrap and the gold paint .
Old Dec 5, 2018 | 06:30 AM
theandies's Avatar
theandies
My spacers fell apart in about 10 years. I called Vette Brakes and Products (manufacturer of my spring but bought through Van Steel) when they were still in business and they sold me some new spacers. I'd call Van Steel and see if they can help you out. You'll probably have to call as it's not a part that they catalog.
Here is my bad spacer thread if you want to look through it:
Bad Composite Spring Spacer Thread
Old Dec 5, 2018 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by gabesaad10
...Ive looked everyone and still can’t find it...
Who did your friend buy it from?
Old Dec 5, 2018 | 10:46 AM
gabesaad10's Avatar
gabesaad10
it has a different shape, it’s wider on the sides and get skinny in the middle
Old Dec 5, 2018 | 10:52 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Sounds like it might be one of the TRW replacement springs....
Old Dec 5, 2018 | 11:59 AM
MelWff's Avatar
MelWff
contact this company
http://www.muskegonbrake.com/product-p/600-101.htm
Old Dec 5, 2018 | 01:53 PM
bazza77's Avatar
bazza77
Indeed it does sound like a TRW , I had an brand new one of those and after trying it I gave it away as well . The 77 sat so high it looked like a 4x4 .But at least I gave it all away .
Old Dec 5, 2018 | 04:47 PM
gkull's Avatar
gkull
I was installing one years ago for a customer who supplied the high arch spring. It would have taken really long bolts to get the ride height correct. So I took the block off and put a nylon spacer in it's place that was maybe 3/16th inches thick.
To Monospring bushing/shims
