C3 Mechanics Please Assist
Old Dec 13, 2018 | 06:01 PM
Robert Butler's Avatar
Robert Butler
Default C3 Mechanics Please Assist
C3 Mechanics,
I need your professional input . What size socket is the exact fit needed to remove the three bolts holding the stock steel pad that holds the rear leaf spring to the aluminum bat wing on a 1980 Corvette ?
Thank you Forum members for being a great resource for all of us learning about these iconic cars.
Robert
Old Dec 16, 2018 | 05:40 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The three bolt heads are a M12 (metric) head bolt, the two larger ones are m12x 1.75 x 90 and the smaller one is m12 x 1.75 x 30.
They torqued... with the car sitting on the ground at 55-75 ft pounds. Never... Ever torque the spring with the wheels off the ground. You can snug the bolts but torque it with the car under full load.
Willcox
Website https://willcoxcorvette.com/
Tech Page http://repairs.willcoxcorvette.com/
Please bump our sale threads if you get a chance..
Old Dec 16, 2018 | 07:17 PM
derekderek's Avatar
derekderek
Hi. Bolt heads or threads? GM used 18mm heads on some larger bolts. So if 3/4 and 19 are loose and 17 and 11/16 too small. That will be the culprit...
Old Dec 16, 2018 | 10:52 PM
Antz81's Avatar
Antz81
I think he means heads, Which are 18mm on these bolts.
To C3 Mechanics Please Assist
