Battery Gauge
Old Dec 17, 2018 | 01:41 PM
Parodi Cigar's Avatar
Parodi Cigar
lionelhutz, Thank you so much for the answer... Off to the garage!
Old Dec 17, 2018 | 03:25 PM
C3 Stroker's Avatar
C3 Stroker
If you decide to go voltmeter, it will look just like stock. Mine from Zip......
Old Dec 17, 2018 | 03:28 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by SteveG75
Here is the easy solution to replace your ammeter:
https://www.zip-corvette.com/68-71-v...gine-swap.html
68-71 Voltmeter Gauge
I would be doing the same in my '75 but Zip doesn't have one for 75-76 yet.
On my list as well......
Jebby
Old Dec 17, 2018 | 08:33 PM
Parodi Cigar
Follow up: I re-wired as I drew on my diagram. It was easy as I just took my original alternator (+) wire (this wire was spliced to the voltage regulator wire and the horn relay wire) and attached it to the new junction block along with my two 4 gauge wires; one leading to the alternator and one leading to the starter.
This seems to have solved the over voltage issue as my voltage (measured at the battery) at idle is now 14.4 and under full load is14.38. I think that is within specified limits. However my stock ammeter is still wonky. It reads negative 5 when engine is off. When running, it reads negative 10 and under full load, it reads negative 15. There was no third wire in the splice as shown on the MAD enterprises Original Chevy System diagram (leading to the ammeter). So, I don't know where the ammeter gets its input and therefore I have no idea how to fix it. I guess a voltmeter is the answer. Lol. Buying one now.
Old Dec 17, 2018 | 08:47 PM
lionelhutz's Avatar
lionelhutz
One lead should be on the horn relay and the other lead should be on a splice part way between the horn relay and the solenoid. I think the horn relay wire is black with a white stripe and the other wire will be black. Both have a fusible link on the end where they connect. You'll want to at least disconnect the ammeter wires if nothing else. It sounds like you left the original wire from the horn relay to the solenoid so you likely want to eliminate it too.
Old Dec 17, 2018 | 10:25 PM
carriljc's Avatar
carriljc
You still need to chase down those ammeter leads and make sure they're not connected to anything. Don't just ignore them since they're obviously hooked up to the system somewhere.
Old Dec 18, 2018 | 03:03 PM
OldCarBum's Avatar
OldCarBum
Please correct me if I am wrong, but I purchased all new OEM gauges for my 73.
I was told that the 73 has a true volt meter and not an amp meter.
If that is the case, couldn't you just replace the 68-72 amp meter for a 73 OEM volt meter?
Old Dec 18, 2018 | 03:51 PM
C3 Stroker's Avatar
C3 Stroker
The '73 had an amp meter, unless you replaced it with a voltmeter. This is the replacement upgrade...https://www.volvette.com/EL74-VOLT.html
Old Dec 18, 2018 | 04:41 PM
OldCarBum's Avatar
OldCarBum
I stand corrected.
This is the volt meter sold by Corvette Central.
There website shows they have them in stock.
FYI
Old Dec 18, 2018 | 06:42 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The face plate number colors are different, 68 thru 71 are green after that they are white IIRC
