Quick T-5 Question for swap (WC T5?)
Old Dec 17, 2018 | 09:41 AM
Jaxley's Avatar
Jaxley
Default Quick T-5 Question for swap (WC T5?)
Hey guys,
Been digging through the forum and trying to determine if this specific T5 will work for a 1981 Corvette. My best guess is that with the casing numbers it's a WC T5 with gear driven speedo. Has torx bolt. Cannot tell if it has Temken Stamped on the counter shaft cover
Main Case Casting
13-52-065-922* 96+ World Class Ford & GM - With and without the reverse spring anchor
Tail Case CASTING NUMBERS:
13-52-066-936 88-95 Camaro World Class (w/speedo GEAR)
I would typically do more research, but I'm passing through where it's listed for sale and it's a ways from home. Any input would be greatly appreciated, even if it's a link to an answer that I didn't find on the form.
Thanks in advance.
Old Dec 17, 2018 | 12:24 PM
Dynra Rockets's Avatar
Dynra Rockets
That model is not a bolt up to your existing bellhousing if that is what you are asking. That is a world class Ford pattern transmission.
You want to go by the tag and not the casting numbers
http://www.britishv8.org/articles/bo...t5-id-tags.htm
Read this page.... https://lugnutz65chevystepside.weebl...info-page.html
Old Dec 17, 2018 | 03:41 PM
derekderek's Avatar
derekderek
I believe that is a GM v6 T5. Bolt pattern is wrong, do you have to buy an adapter to fit it to a Chevy bellhousing. Even though it's a GM trans it's a Ford pattern on the front. Gear ratios are wrong. Way wrong. does the tag boulders on the one of the bolts that attaches the tail housing to the transmission case. 13 space 56 and then the next three digits that's what I'll tell us what the transmission really is. But it's a GM v-6 with a too deep first gear so it ain't going to work very well.
Old Dec 17, 2018 | 05:03 PM
Jaxley's Avatar
Jaxley
ok, those are the answers I was looking for. The guy doesn't have the info tag and the only info I had was the pictures with the casing number. Such a shame... really good price on this T5, but I'll let it pass and use the above information going forward to get a good T5.
again, thanks all!
To Quick T-5 Question for swap (WC T5?)
