steel leaf spring advice needed (71 LT-1).
Given this experience, I'm thinking of going back to a steel spring.
Has anyone had any experience, good or bad, with the Muskegon 9 or 7 leaf steel springs?
The car is mostly a cruiser and I was wondering if the 7 leaf would be too stiff.
Thanks in advance.
I don't know who makes these, but I don't think very many places are so chances are you'll get the same mfg from most suppliers.
I did talk to Shawn Fox about this problem at the time and she said they didn't have that issue. I would buy from Muskegon and if there's a problem they'll stand behind it. Just be sure to measure it when you get it and check the dimension between the cover mounting bolts.
Gary
I didn't find the ride any stiffer. General driving was the same.
However, if you hit a low/high spot in the road, it would not compress as far as the 9 leaf. You simply followed the road.
The reason to add the 7 leaf was to stop the "squat" of the rear on hard acceleration.
Shocks will determine the ride much more than a spring.
Some people will add stiffer shocks to overcome a weak spring.
If you have firm shocks and a stiff spring, then you would lighten up on the shock.
Barry
I would also find the root cause of why the spring cracked, what condition is your frame in. Have heard a few stories from ppl who have had there composite spring crack and the real problem was due to a poor frame putting stresses on the spring that it was not designed to withstand.
