‘73 454 Fuel Pump Return Line
Old Dec 20, 2018 | 11:11 PM
davidbii's Avatar
davidbii
Default ‘73 454 Fuel Pump Return Line
Quick question. I’m installing an electric fuel pump and I am going to use a fuel pressure regulator with a return line. I’m running a new feed line, but can I use the existing fuel return line that’s already on the car, or should I run a new one and make a new return port on the tank?
Old Dec 21, 2018 | 12:14 AM
TimAT's Avatar
TimAT
Unless your new pump has a super high return rate and the existing line can't keep up, no reason not to that I can think of.
Old Dec 21, 2018 | 12:28 AM
ronarndt's Avatar
ronarndt
I used the existing return line on my 68 convert with NOM 454 and electric pump with pressure regulator with return port. It works fine.
Old Dec 22, 2018 | 09:19 AM
Big Block Dave's Avatar
Big Block Dave
On my 74, i ran a new -8 feed line, and used most of the factory 3/8 feed line as my return, and plumbed it to the tank port on the drivers side where the plumbing from the charcoal canister ran to. I then ran that canister plumbing to where the factory return line went on the pass side, stepping the 3/8 down the 5/16 or even 1/4 inch size that is there
In my opinion, the factory return line is too small to satisfy the needs of a return style regulator and electric fuel pump, unless the pump is relatively low psi like 7. I see that at least one previous poster has done it successfully, and that's great.
Aeromotive wants you to run the same size return line as feed. My return is one size smaller, and I can't get the pressure as low as I'd like. My pump is a 14 psi aeromotive street strip. Lowest i can get pressure is probably in the high 6 range, and I couldn't run my qjet with that. Fine with holley.
To ‘73 454 Fuel Pump Return Line
