76 idle vacuum
Old Dec 23, 2018 | 11:04 PM
BobRiley's Avatar
BobRiley
Default 76 idle vacuum
So, new Holley 600, Edelbrock EPS manifold, OBS headers and side exhaust, new vacuum lines, L82 motor. 13in vacuum at idle at about 800 rpms. Isn't this low? Or do I have an aftermarket cam in it? No history. Its original motor, so I guessed no, but has distinctive lope to it. Any way to know for sure?
Bob
Old Dec 23, 2018 | 11:24 PM
BLUE1972's Avatar
BLUE1972
I would expect stock vacuum in the 17 to 20 range.
Put a degree tape on the damper, pull the valve cover and put a dial indicator in the rocker and measure the lift and duration - both intake and exhaust - then you know what you have.
Double check your timing first.
Old Dec 23, 2018 | 11:28 PM
BobRiley's Avatar
BobRiley
Thanks! Timing is another topic. If we have a bit, maybe 5 degrees advanced, that effect it? What should best be? Seems to run real well there.
To 76 idle vacuum
