Bought a 1976 corvette this summer. A lot of small things wrong with it. Me and dad replaced the water pump, replaced the dry rotted rubber fuel lines, etc.
My question is in regards to the coolant reserve tank. The rubber hose running from the tank to the top of the radiator is there but the second valve on the tank doesn’t have a hose. From what I have gathered, there should be an overflow hose there. I can’t find anything on it. Coolant occasionally splashes out of that open valve on the reserve tank.
Where does that hose go, how long does the hose need to be, what size is the hose, where does that hose connect, and why wasn’t the hose on the car when I bought the thing?
If you take note of forum members engine bays, notice that the second nipple on the rez cap is almost always empty. They dry up, crack, fall off.
I installed a short section of clear hose on that fitting and curved it downward and forward to the ground. I figure if the tank ever got hot enough to blow out that nipple, that it should spew on the ground, not in the engine bay. Using clear hose I can see what's going on: nothing
The coolant seems to be coming out of that nipple somewhat regularly. Almost every time I drive it, it seems. Hard for me too tell how much coolant, though. I check the radiator quite bit and the level seems to be holding.
I replaced the water pump and flushed the coolant recently. Also hard for me to tell if the engine is running hot because none of the gauges are functioning.
It would be a good idea to get your temperature and oil pressure gauges working. If the temp goes way up or the oil pressure goes way down, you will destroy your engine if you keep running it because your gauges don't work.
If you can't fix the gauges soon, then at least purchase one of the radiator caps with the temp gauge built into the cap.
I think Summit Racing carries them.
A couple of things to check:
1. Make sure the thermostat is functioning correctly,
2. Check radiator temp with a thermometer or using the cap mentioned above,
3. Check coolant level,
4. Make sure the spring is in the lower radiator hose to keep the hose from collapsing.
My 73 has the hose attached to the overflow tank and it runs to the ground.
Thanks for the tips. I believe the issues I’m having with the car’s gauges are water related. The previous owner had 3 corvettes and didn’t garage this one. The window hardware failed on the driver side at some point while he owned it. I believe there is some water damaged to the fuse box which is causing the gauges to malfunction.
I have a friend who is a prominent member on this site and good mechanic. I’m holding tight until I can get it to him for repair.
