Identify transmission
Old Dec 30, 2018 | 02:23 PM
tehjrow's Avatar
tehjrow
Default Identify transmission
I have an 81 C3 and am wondering how I can identify which transmission it has in it. It's a factory 4 speed car but it doesn't have the original engine (has a small journal 327) so I'm not sure it has the original Borg Warner Super 10 transmission either. If I crawl under it, where am I looking for identifying marks?
Old Dec 30, 2018 | 06:53 PM
Duke94's Avatar
Duke94
http://www.drivetrain.com/parts_cata...rhaul_kit.html
Old Dec 30, 2018 | 07:34 PM
BKarol's Avatar
BKarol
http://pontiacpower.org/BW.htm
Old Dec 31, 2018 | 04:33 AM
hunt4cleanair's Avatar
hunt4cleanair
This link is to an article on 78 four-speeds including the Borg Warner. Study the B/W photos to figure out where to look for the assembly codes. Then you can use the tables linked above to find the specific model. It also explains how to interpret the assembly codes you'll find. The VIN derivative you can check against the vehicle identification number tag on the driver's side windshield tag to determine if its the original four-speed to the car.
http://www.hunt4cleanair.net/Articles/fourspeeds.pdf
Old Jan 2, 2019 | 04:52 PM
tehjrow's Avatar
tehjrow
Old Jan 2, 2019 | 04:59 PM
tehjrow's Avatar
tehjrow
The VIN code on top starts with 1BS, so it appears to be the original Super T-10. Thanks!
To Identify transmission
