Window rollers
Old Dec 31, 2018 | 11:19 PM
BobRiley's Avatar
BobRiley
Default Window rollers
anyone got a good link to a complete set of wearable parts for the 76 window reg and track and mounts? Can’t seem to find a list
of all the rollers and such I’ll need. Both doors bad. Want to have it all when I take it apart. Thanks in advance
Old Jan 1, 2019 | 06:01 AM
croaker's Avatar
croaker
Old Jan 2, 2019 | 07:48 PM
BobRiley's Avatar
BobRiley
this is all I can find. The magazine article shows many more pieces. I really hope to take the door apart and have all the rollers, rubbers, bushings,etc when I do. Zip corvette site is very hard to find parts in.
Old Jan 2, 2019 | 09:41 PM
clatgeo's Avatar
clatgeo
Default Window Rollers
I am rebuilding my manual driver window in 1970 Corvette. I had the same problem getting a list of replacement parts. Here is my parts list for a manual driver window from Corvette Central:
28306269-75 Convertible Outer Window Seal / Felt =right$69.95=right1=rightPair=right$69.9 5
28314968-82 Window Regulator Roller =right$21.95=right1=rightSet=right$21.95
28303468-77 Door Glass Lift Track Rebuild =right$39.95=right1=rightKit=right$39.95
28308168-77 Door Glass Rubber Washer =right$4.00=right1=rightSet=right$4.00
48133456-79 Window Crank & Lock **** Retainer Clip =right$2.15=right1=rightSet=right$2.15
37300568-82 Door Handle Gasket =right$4.95=right1=rightPair=right$4.95
28302169-96 Door Gls Anti Rattle Cushion =right$29.95=right1=rightSet=right$29.95
28305568-79 Manual Window Regulator Bushing w / Washer =right$11.95=right1=rightSet=right$11.95
28308968-82 Door Outer Window Seal Screw =right$1.95=right1=rightSet=right$1.95
28314868-80 Window Crank To Regulator Shaft - Ex Power W=right$11.95=right1=rightEach=right$11. 95
28307868-77 Door Rod Anti - Rattle Grommet =right$4.75=right4=rightEach=right$19.00
48102956-79 Window Crank / Lk Kn Spacer - Gray =right$4.50=right1=rightPair=right$4.50 .
Old Jan 3, 2019 | 11:42 AM
Peterbuilt's Avatar
Peterbuilt
You can get some of the rollers from NAPA:
https://www.corvetteforum.com/forums...r-my-71-a.html
You have to order this one from a Corvette parts supplier:
https://www.zip-corvette.com/catalog...roller-slider/
To Window rollers
