Question on power to manual brake conversion
My engine doesn't have enough vacuum for the booster without the extra pump. Manual brakes are the right answer instead of the vacuum pump workaround.
I already have a 1" so I will start with that anyway.
Received 3,220 Likes
Although I am still bitter that the original guy at Wilwood never asked me about which calipers I had when he recommended the 1" bore for the power brakes. At least I can re-use that MC for the manual!
At least Keith made sure he knew which calipers I had before recommending the 1" for manual.
Ditto.... If you have power steering it doesn't take much to plumb in a hydrobooster. There are some really small kits out there for it too. Here is a unit that is a direct bolt on for a C3 http://www.powerbrakeservice.net/new...ydroboost.html
