accessory position?
Old Jan 20, 2019 | 01:22 PM
olelucky's Avatar
olelucky
Default accessory position?
to my knowledge my 72 coupe auto doesn't have a accessory position on the steering column. (if that's wrong i have more questions) It doesn't turn backwards to listen to the radio, etc. When I turn if forward to the run position, isn't it putting current to the point? seems it would burn the points if they are in the closed position. Could someone explain this to me?
thanks
Old Jan 20, 2019 | 01:41 PM
Mooser's Avatar
Mooser
It should have an accessory position for the key and yes if in the run position and the points are closed it' put power through them and that's not a good thing (with the car not running of course)
M
Old Jan 20, 2019 | 01:45 PM
Mooser's Avatar
Mooser
Check post #7 here for some of Jim Sheas input
https://www.corvetteforum.com/forums...-position.html
M
Old Jan 20, 2019 | 01:48 PM
Mooser's Avatar
Mooser
And maybe post #8 here
M
Old Jan 20, 2019 | 02:03 PM
olelucky's Avatar
olelucky
thanks Mooser, I'll look into that
Old Jan 21, 2019 | 02:55 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
wiggle the steering wheel while you try and go to the acc position. If it doesnt work , it may be out of adjustment
To accessory position?
