Clutch Z-bar: All the same?
Old Jan 24, 2019 | 09:09 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Default Clutch Z-bar: All the same?
Quick simple question. Are all the model year parts (both C2 and C3) the same design (same arm lengths and angles)?
My guess is Yes, but I'm open to correction.
Thanks for any constructive input.
Old Jan 24, 2019 | 09:47 PM
69ttop502's Avatar
69ttop502
This was a quote from JohnZ on another thread to the same question you asked.
“There were some subtle differences in the angular relationship between the upper and lower levers over the years both between different years of SB's and between SB and BB in certain years, but I haven't researched it. Most of the resto houses just sell two - one for '63-'65 SB's, and one for '65-'67 BB, '66-'67 SB, and all '68-'81. The differences really only matter in that you also need the matching lower pushrod to the clutch fork with each one, and there are three of those.
Old Jan 24, 2019 | 10:34 PM
ignatz's Avatar
ignatz
For what it's worth, I've been able to break the welds and move the clutch fork arm around and reweld it.
Old Jan 24, 2019 | 11:42 PM
buns's Avatar
buns
Old Jan 24, 2019 | 11:46 PM
buns's Avatar
buns
Old Jan 25, 2019 | 12:27 AM
gkull's Avatar
gkull
Mine came with 2 holes from Keisler Engineering. I drilled another one down lower, so it moves the lower arm faster for less pedal travel to disengage the clutch.
are you going to be at the 24 hours of daytona race on Saturday. We were thinking about flying in
Old Jan 25, 2019 | 10:51 AM
69427's Avatar
69427
Lotsa good information here, gentlemen. I do appreciate it.
I'm currently cutting up some aluminum tubing and plate to make a slightly lighter z-bar (I'm running out of ideas to get additional weight off the front of the car). I have a "spare" z-bar on the shelf to use while I make the welding jig, but I don't know the actual vehicle it came off of. I'll do some measurements of this bar, and then see if it's better to just pull the current one off the car to use when making the welding jig.
Thanks again.
Old Jan 25, 2019 | 02:41 PM
pauldana's Avatar
pauldana
Originally Posted by gkull
Mine came with 2 holes. I drilled another one so it moves faster
Thanks again.
Hardness on the Z bar....
I also put in an extra hole so as to have a quicker and shorter clutch throw.. BUT,,,,,,,,,,,,,,,,,,,,,................ .............
the mettle is friggen hard!!!! I could NOT drill this mettle... so I had to have my Zbar water jetted to get the third hole..
Old Jan 25, 2019 | 04:34 PM
Big2Bird's Avatar
Big2Bird
Thanks again.
Your now in that $100@lb zone.
Old Jan 25, 2019 | 04:42 PM
Big2Bird's Avatar
Big2Bird
Mike. Do this one. My son bought me the strut kit from speed direct. $160.
It weighs nothing. Make your own brackets out of alum, and buy the cylinder. Takes 3 lbs off up high. And, it works far better. Even Doug likes it, and he is NCRS crazy.
Old Jan 25, 2019 | 07:58 PM
69427's Avatar
69427
Well, I hope the zone I'm in isn't quite that expensive.
To be honest, half the reason I've been on this path is just for the pure engineering enjoyment of it (most hobbies are money pits of some sort). I spent most of my adult life doing circuit design, and now I'm finally getting to get some return on my money for all the tuition dollars I spent wading through the mechanical engineering classes my freshman and sophomore years.
Oh, I agree on changing the hood prop (the weight's up front and up high). I did the hood prop/bracket setup in aluminum several years back. I did have to change the (version 1 aluminum) prop rod to a steel piece, as the aluminum rod was either too flexible or too big aesthetically.
Old Jan 25, 2019 | 08:01 PM
Big2Bird's Avatar
Big2Bird
How about bumper brackets? They weigh a bunch.(I should have known about the hood thing).
The 81 has this massive battering ram that must weigh 40lbs.
Old Jan 25, 2019 | 10:16 PM
69427's Avatar
69427
The rears are aluminum. The front supports are stock, as I haven't come up with a combo that I'm comfortable with yet.
Old Jan 26, 2019 | 09:58 AM
derekderek's Avatar
derekderek
I think you will find why the Z-bar metal is too hard to drill as soon as you step on the clutch with that aluminum Z-bar. The big heavy bumper brackets are a safety issue and there are many arguments when people wanna convert to 68-72 bumpers.
Old Jan 26, 2019 | 11:06 AM
69427's Avatar
69427
Originally Posted by derekderek;1598761554[b
]I think you will find why the Z-bar metal is too hard to drill as soon as you step on the clutch with that aluminum Z-bar.[/b] The big heavy bumper brackets are a safety issue and there are many arguments when people wanna convert to 68-72 bumpers.
Is it your thought that I'm unaware of material strengths, forces and torques, and possible non-engineering reasons why Chevy put boatloads of steel and cast iron in our cars instead of aluminum, titanium, and magnesium?
Just curious.
Old Jan 26, 2019 | 11:21 AM
derekderek's Avatar
derekderek
they used boat loads of cheap soft steel because, like every other 60's to 80's car it was designed to last about 5 minutes longer than the warranty period. fed govt mandated better crash safety so they used more. once cars cost 50 to 60k new and fed govt mandates certain fuel economy standards, out comes the Aluminum, Magnesium and composites... they used hard steel in the z-bar cuz the cheap soft stuff didn't hold up. do I know you personally and think you have no idea what you are doing? no. do i think the AL pivot will hold up? i hope i am wrong... but there are MANY more people on this forum that can fab a z-bar than can design one.
Old Jan 26, 2019 | 11:49 AM
69427's Avatar
69427
That's right, sport, you don't know me. You have no clue what my educational/technical background is. You also did not have the common courtesy to ask me any details on the construction of this part, nor any of the calculations I went through to pick out the pieces I intend to use before you pronounced that this endeavor would be a surprise/failure.
Did I at least get this side part of the project correct?
To Clutch Z-bar: All the same?
Old Jan 26, 2019 | 04:39 PM
69427's Avatar
69427
Originally Posted by buns
I measured the arm angle on my spare bracket. It's the early small block version. So, looks like I'll just pull the present shaft off of the car to weld up the jig. My thanks to buns for the information here.
Old Jan 26, 2019 | 06:46 PM
BLUE1972's Avatar
BLUE1972
If the AL fails , you could go to Dupont Vespel Bearings and Hemi rod ends. It may help. You would have to machine a step in the tube or insert another tube to make the step.
Experimenting is always fun .. Best of luck..
Old Mar 31, 2023 | 01:00 AM
Corvettes White's Avatar
Corvettes White
Made this for fun. But forgot how it went together. Came across this post. George
