Exhaust Manifold date
Old Jan 25, 2019 | 01:26 AM
blackvette68's Avatar
blackvette68
7th Gear
Default Exhaust Manifold date
Hi,
i am looking for a correct set of exhaust manifolds for my BB LS5 Engine.
The Manufacture date of the block reads February, 27, 1970.
I know the correct casting numbers are 396 98 69 lh and 388 08 68 rh.
What casting date of the exhaust Manifolds is correct for that engine block?
I am confused, there are Manifolds with and without bores / threads for the air in the exhaust ports.
which one´s are correct for my engine?
Thank you in advance for your support
OLI
Old Jan 25, 2019 | 01:00 PM
Kacyc3's Avatar
Kacyc3
Originally Posted by blackvette68
Hi,
OLI
You should try https://www.corvetteforum.com/forums/c3-general-119/ as you would probably get better results there.
Old Jan 25, 2019 | 05:33 PM
MelWff's Avatar
MelWff
your engine didn't come with an air pump so the manifold wouldn't have the fittings for the connection. I have read for NCRS full credit the date has to be within 6 months of the final assembly date of the car.
To Exhaust Manifold date
