Tune up Dizzy
Old Feb 2, 2019 | 07:45 AM
fake's Avatar
fake
Default Tune up Dizzy
Lots of rust on weights and springs any suggestions? Is there a cleaning method?
Old Feb 2, 2019 | 09:10 AM
HeadsU.P.'s Avatar
HeadsU.P.
Take a picture of how the weights are oriented. Remove the two weights and two springs and plop them in a plastic cup with some of rust removing household cleaners like CLR. Let it soak couple hours. Meanwhile, some say good ol WD40 will remove rust from the distributor plate. IDK
When you re-assemble, spray some White Lithium grease under the weights. Can be found it Walmart, red spray can. Won't fling off at high RPM and won't melt.
Old Feb 2, 2019 | 12:42 PM
fake's Avatar
fake
Thanks will do!
Old Feb 2, 2019 | 12:57 PM
Big2Bird's Avatar
Big2Bird
I would wire wheel them, coat with silicone spray, wipe dry, then reassemble. No grease.
Old Feb 2, 2019 | 01:10 PM
jackson's Avatar
jackson
pitted springs will break sooner than later … not an issue w/ weights
Old Feb 2, 2019 | 01:13 PM
Big2Bird's Avatar
Big2Bird
Good point. New springs are cheap.
Old Feb 22, 2019 | 07:40 AM
fake's Avatar
fake
Default Dizzy Springs
Where and who sells the springs?
Old Feb 22, 2019 | 07:53 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Well...what distributor is it?
Jebby
Old Feb 22, 2019 | 02:39 PM
fake's Avatar
fake
Default HEI 77 car
Distributor model No 1103256 L-82 manual
Old Feb 22, 2019 | 02:40 PM
Big2Bird's Avatar
Big2Bird
Mr Gasket 928G. Use the two gold springs to start.
Old Feb 22, 2019 | 03:03 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This!
Jebby
Old Feb 22, 2019 | 03:08 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
E-mail Lars and get his paper on Distributors......good reading and everything you need to know.
Stuff like advance canister stops, how much they pull, distributor gear endplay and shimming, etc.......
Replace the pickup coil no matter what......the 70's units were known for getting brittle and having the wire separate from the pickup-coil.....if it is old, it is going to happen...just a question of when.
Jebby
Old Feb 22, 2019 | 07:34 PM
fake's Avatar
fake
Thanks just trying to get this car back on the road this spring!
To Tune up Dizzy
