SB Torque Sequence
Old Feb 14, 2019 | 07:07 PM
Vettesic's Avatar
Vettesic
Default SB Torque Sequence
Looking for the torque sequence for head bolts on a 350 in my 71. Also ft lbs. Are they tightened gradually?
Old Feb 14, 2019 | 07:19 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Don't have exact sequence committed to memory but start with the bolts at the centre of the head and work outwards alternating back and forth until all the outside bolts are initially torqued to 40 ft-lbs and then final torque to 65-70 ft-lbs. Others will chime in to correct me if I've erred.
Old Feb 14, 2019 | 07:33 PM
HeadsU.P.'s Avatar
HeadsU.P.
An actual drawing of sequence can be had by search on Google. Print that out and lay it on your fender. Cast iron heads are not as finicky as aluminum. The softer metal should be torqued in four if not five steps to avoid hairline cracking the head. The first tightening of the bolt is just "snug". Then take your total torque value and divide by the number of steps you plan the do.
Example:
Snug > 30 > 45 > 60 > 75 > 90. This will guarantee a leak free head gasket and no warping / cracking of the castings. Use a thread sealant on the bolts that is compatible with Glycol.
Some gasket manufacturers recommend a follow-up torqueing after several heat cycles. Of course the bottom row bolts will be challenging with the exhaust in the way.
Old Feb 14, 2019 | 07:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Feb 15, 2019 | 08:45 AM
Vettesic's Avatar
Vettesic
Ok thanks. I did do a search but that renders so many different patterns for a 350. So I wasn’t sure which actually applies. I should invest in a GM shop manual.
Old Feb 15, 2019 | 08:56 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
From 350's to 632 Big Chiefs, I was taught to start in the center and go in a CW or CCW "spiral" working your way outward in a two step pattern......45 ft/lbs. step1, 75 ft/lbs. step two.....for ARP bolts. Stock replacement subtract 10%. Use PTFE on the head bolt threads and moly lube under the shoulder/washer.
Jebby
Old Feb 15, 2019 | 09:06 AM
HeadsU.P.'s Avatar
HeadsU.P.
Jebby
Yes, Clockwise is for the Northern Hemisphere. C.C.W. for the southern hemisphere.
Old Feb 15, 2019 | 09:51 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I count out loud so I dont forget which bolt I'm on incase my mind wanders. ...child of the late 60s 70s
Old Feb 15, 2019 | 10:05 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Stimpy, you idyot
Old Feb 15, 2019 | 10:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Well...I go CW because I spent 30 years in the thumb....but Texas goes CCW and they are still in the Northern Hemisphere LOL!
Jebby
Old Feb 15, 2019 | 10:19 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Sounds Legit....as long as no one is standing around LOL! 🤣
Jebby
Old Feb 15, 2019 | 02:35 PM
jim-81's Avatar
jim-81
Yeah I mark the heads by the bolt location with the bolt number and say the number out loud as I'm going around.
Old Feb 15, 2019 | 03:29 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
This may help you guys next time you tighten head bolts.
To SB Torque Sequence
