Torque question
Old Feb 15, 2019 | 06:50 PM
Ole Red 77's Avatar
Ole Red 77
Default Torque question
Anyone know the torque spec for the castle nuts on tie rod ends for a '77?? Thanks in advance.
Old Feb 16, 2019 | 11:09 AM
Big2Bird's Avatar
Big2Bird
37 lbs.
Old Feb 16, 2019 | 11:15 AM
P3x's Avatar
P3x
4th Gear
Default Tie Rod End Torque
Looked in a 66-82 Corvette Shop Manual and did not find the torque listed in the torque Specifications chart.
The installation instructions state - ...torque to specifications then advance nuts just to insert cotter pins
Have a Chilton Corvette Repair and Tuneup Guide which lists the following:
Tie Rod End to Knuckle - 29-36 ft.-lbs
Tie Rod End Lock Nut - 39-53 ft.-lbs
Tie Rod Housing to Cover Beam - 47-61 ft.-lbs
Old Feb 16, 2019 | 11:53 AM
jb78L-82's Avatar
jb78L-82
Tight...and then advance the nio to insert cotter....cannot come loose with a cotter....not kidding
Old Feb 17, 2019 | 10:51 AM
Ole Red 77's Avatar
Ole Red 77
Thank you.
To Torque question
