help identify relays
Old Feb 17, 2019 | 08:32 AM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Default help identify relays
Can someone please help me identify the relays on the pictures?
I can't find them under those part numbers from AIM on any site (only NOS available). The one pointed with green arrow is power window circuit breaker?
The thing is that my car is a 71 with a TH400. I don't have any of the sensors and carburetor solenoids on my car. The only things left are kickdown switch on the gas pedal.
Are these relays neccessary for everything to work?
Old Feb 17, 2019 | 12:41 PM
MelWff's Avatar
MelWff
TCS stands for transmission controlled spark. it is an emissions system designed to provide vacuum advance only when the transmission is in high gear. Unless you want them for originality there is no need for them.
Old Feb 17, 2019 | 12:42 PM
Primoz's Avatar
Primoz
What about the kickdown? Does that work solely from the gas pedal switch?
Old Feb 17, 2019 | 12:44 PM
MelWff's Avatar
MelWff
yes the th400 uses the kickdown on the gas pedal in conjunction with the vacuum modulator to control gear shifting.
Old Feb 17, 2019 | 12:53 PM
Primoz's Avatar
Primoz
What about the ground wires that connect to those relays?
Will everything work without them?
Old Feb 17, 2019 | 12:55 PM
MelWff's Avatar
MelWff
what exactly do you mean by "everything"? How is the vacuum advance hose on your distributor connected, directly to the intake manifold or carburetor?
Old Feb 17, 2019 | 12:56 PM
Primoz's Avatar
Primoz
Carb!
To help identify relays
