Which plug wire
Old Feb 17, 2019 | 04:42 PM
shipahoy's Avatar
shipahoy
Default Which plug wire
I am looking for a set of new plug wires for my 79 L48 coupe. I don't want to run them where the factory wires go, too much of a pain. I'm thinking a set of factory 79 Camaro plug wires would work.
Old Feb 17, 2019 | 07:26 PM
Iceaxe's Avatar
Iceaxe
Buy a set of custom plug wires (Accel #5041B are what I used) as they are made to be cut to length. Needing custom length plug wires is pretty much standard for anyone running headers. The custom plug wires are the same price and installation is not much harder as you just install the wire, cut off the excessive length and install the end.
Old Feb 18, 2019 | 11:50 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Taylor 73051....cut your own.
Jebby
Old Feb 18, 2019 | 02:40 PM
shipahoy's Avatar
shipahoy
Thanks, I don't want to cut my own I want something off the shelf.
Old Feb 18, 2019 | 04:09 PM
HeadsU.P.'s Avatar
HeadsU.P.
Pre-made MSD 8.5 mm thick with HEI ends and 90* bent sparkplug ends with silicone burn resistant boots. I believe they were around $90 a set at Summit, but it will be the last set you'll ever buy. Might even come in different colors. No stereo interference. No cutting, no assembly. They also make a 9 mm but usually that size will not fit most wire looms.
Check out my profile & album for some pictures of them installed.
To Which plug wire
