Engine identification help
Old Nov 1, 2002 | 04:38 PM
brimcc's Avatar
brimcc
Default Engine identification help
I found a 350 at a local wrecking yard. The owner says it came out of a 78 Vette. I pulled the #'s and would like to find out it in fact this is the original 78 Vette motor.
Block # 3970010
Head # 462624
I am not going to pull it apart if it's not the proper engine. Did the 78-79 Vettes come with 4 bolt mains. What make 's the Corvette motor different from other 350's?
He wants $250 for the motor.
Old Nov 1, 2002 | 04:48 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: Engine identification help (brimcc)
3970010 - block casting 1969-1979 4-bolt 350
462624 - head casting 1978-1981 350c.i. 1.94 / 1.5 Z-28 Camaro
462624 - head casting 1976-1987 305c.i. - 350c.i. 76cc chambers - (apparently, these heads are crack prone)
You'll want to check the front engine pad for numbers that may help to identify the block further.
Old Nov 1, 2002 | 05:02 PM
brimcc's Avatar
brimcc
Default Re: Engine identification help (67HEAVEN)
Where is the front pad? I have looked on my 305 that I currently have and can't locate it. Is there anything else I should look for?
Old Nov 1, 2002 | 05:09 PM
67HEAVEN's Avatar
67HEAVEN
Down front just below the heads near the water pump.
Example.....
Old Nov 1, 2002 | 05:12 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I do believe that the "010" block was made in both 2 and 4 bolt configurations. Drop the oil pan to check. Chuck
Old Nov 1, 2002 | 05:48 PM
brimcc's Avatar
brimcc
Default Re: Engine identification help (Chuck Gongloff)
Funny, I have no markings on that pad on my 305 :confused:
Old Nov 1, 2002 | 06:05 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Your block was probably decked.
Ed
To Engine identification help
