T Top drainage tubes
Old Mar 10, 2019 | 04:34 PM
Silent Thunder's Avatar
Silent Thunder
Default T Top drainage tubes
Just bought a 72 coupe and the previous owner stated the drainage tubes for the T tops need replacing. Is this straight forward and how much of a job is this. Basically how??
Old Mar 10, 2019 | 05:09 PM
A8skyhawk's Avatar
A8skyhawk
I think you are talking about the Astro ventilation drainage tubes. I recently replaced mine and it was surprisingly one of the easier more straight forward jobs. The vendors sell kits that come with everything you need from the tubes, clamps, and pop rivets. Probably the toughest part is drilling out the old rivets (3 per tube) as the angles can be a little tricky given the space available under the rear deck. All told I think you could change them in under an hour - figure 45 minutes to figure out one side and then only 15 to do the other side.
Old Mar 10, 2019 | 05:50 PM
Silent Thunder
Yes that is what I was referring to. Thanks for your reply.
To T Top drainage tubes
