getting ready to test the electrical circuits...
Old Mar 11, 2019 | 11:08 AM
DorianC3's Avatar
DorianC3
Default getting ready to test the electrical circuits...
The engine and trans are out, as it the entire interior including steering column, dash, carpets... you name it.
I would like to test all the circuits and lights safely while everything is stripped down.
I bring power in through the black spliced to red wire from the horn buzzer ?
Anything I need to be careful for ?
MTIA,
D.
Old Mar 11, 2019 | 11:09 AM
DorianC3's Avatar
DorianC3
And any other suggestions on testing while everything is apart ?
Old Mar 11, 2019 | 12:46 PM
wadenelson's Avatar
wadenelson
Suggest you put a fuse holder inline with your power lead either in case you screw up testing something, accidentally touch something hot to ground, or if your harness has a dead short in it somewhere.
Old Mar 11, 2019 | 02:32 PM
Richard454's Avatar
Richard454
I'd skip throwing power on it till you do a continuity test first.....
Old Mar 12, 2019 | 03:31 AM
DorianC3's Avatar
DorianC3
Thanks Gents !
Ha ! Very clever. Of course ! I should have thought of that. That makes a lot of sense.
And you would... go through all the circuits and check for continuity? Any particular order? Anything not to miss... or go hog wild and check everything ?
Old Mar 12, 2019 | 06:24 AM
Bikespace's Avatar
Bikespace
After following the other suggestions, I'd use a power supply with a digital display and a current limit. You'd be less likely to cook anything, and you can use it to find shorts and other current draws.
To getting ready to test the electrical circuits...
