Front Brake Hose Crush Washer
Does anybody know the size/measurements of the front brake hose crush washers between the caliper and hose? Or a NAPA part number maybe? I believe they are 7/16ths but how wide or thick is required?
If you order a new set of hoses, they will come with new copper washers. Or, you can go to your local FLAPS and ask for one of the hoses (which should include a washer) and when they bring it out take the washer and ask then for some of these washers.
Many auto parts stores have a rack of miscellaneous items labeled HELP. One of the items typically on the rack is a small blister pack of these copper washers.
You can also check Amazon... here and here
Good luck... GUSTO
Good luck... GUSTO
CanadaGrant (03-13-2019)
CanadaGrant (03-14-2019)
You can try taking one of the original washers to a local Harley Davidson shop.
Harley uses the same washers for all the aftermarket brake calipers and lines and they usually have a good supply.
Harley also has them in aluminum and the OEM caliper washers have a rubber seal that work great if you have any lines that like to seep.
I preferred the washers with the rubber seal and used them on all my show bikes with polished calipers.
I ordered a box with various copper crush washers. Just used it today when putting new lines in a classic Fiat. The only dimension that matters it the id of the washer. It must be reasonably close to the od of the brake line or banjo bolt. Also the quality / price of the washer isnt too important because you want cheap metal that will crush easily.
Thanks for all the info guys. 73ls1's measurements came in handy at the parts store today! The two I had in the front that Napa gave me were just a hair larger and one would weep very slightly. Looks good now.
Received 2,128 Likes
A true crush washer is round on one side, flat on the other. To use a ordinary hardware copper washer will likely result in a leak.
As I recall, from the NAPA counter parts man, the flat side of the washer always goes towards the caliper. (And that includes the more modern banjo fittings too)
And, its a one-time-deal. Once you crush it with a wrench, disassemble, they are to be thrown away and not reused. (but I have)
I always thought the crush, or curved side was on the caliper because the hose face is perfectly flat and that the crush or curved part of the washer was on the caliper because the caliper surface is sort of machined but not really well. It has small grooves/lines showing. Who knows...
anyways the copper washer smashes down so much that it probably doesnt matter because both sides mold to their respective mating surfaces. After you tighten it up the copper washer no longer has a curved side but two shinny flat sides with circular scratches and grooves matching the mating surfaces.
