QA1 coilover SU-1478 vs Sharkbite coilover SU-1302
I'm on the fence about which one would be better for my application. Originally I was looking at Sharkbite (love the name) but then saw the QA1 stuff. The $ difference is 100$ between the two kits. I have researched forums but I'm a suspension novice. Yes I know they aren't true coilovers..
Basically I have a mostly stock C3 '76 with sagging stock front suspension. I would like max adjust-ability for ride quality, height, and looking at a medium spring. She is basically a daily driver but occasionally I like some spirited driving (not a track day car). I would like at some point to upgrade the back suspension which was previously done with a fiberglass spring and was looking at Sharkbite for the rear at some point in far off future. I would like a more modern flexible ride without major $$$ (ridetech, chassis mods, etc). I sent an email to a tech at Zip Corvette suggested to me during a support chat but have yet to receive a response.
I simply included zip item numbers for ease. Both of these are dual adjustable. $1k is too much too spend and makes me cringe since I'm on a budget. I've also read the vansteel requires some chassis modifications which is beyond my skills.
No mods needed at all- except when doing the rear coilovers- which just requires an upper bracket to reinforce the OEM mount.
I'd certainty give them a call -it's free even have 800number!!! Tell them your type of driving- and maybe find the dual adjust is not really needed/suited for you and your car. Then end up with a better piece- suited for your driving and save $100.
AND nothing against the Zip tech- but I'd feel a lot more comfortable spending that kind of money with a guy who understands C3 suspensions and can explain the differences- not just not read off a spec sheet.
I called VanSteel today and ordered the front semi coilovers. I went with the single adjustable and the spring they suggested. I'm excited since this the first major upgrade I've done in quite a long time! 😁
