Tire suggestion and experiences
I have done lots of searching and reading. I am limited due to my rims but want to see what the experiences in this group is with various tires and their performance for street driving.
Size: 255/50ZR 17. Riken Raptors are what I have. They seem poor in traction. Not sure if logic is sound but even when I spin from a dead stop very little rubber is left on the ground....Compound appears to be very hard. Tires are at least 10 years old.
From the size it looks like I can get Nitto 555 G2's. I have looked at size options but I lose contact area with much change. Wider is not an option. it looks like I could do a 245/50R17 and get close to diameter and contact area. Wheels are 8.5". That opens up a couple brands.
A 235/55R17 get me lots of brand options in Ultra Hi Perf tire which is what I want but i lose .7 in width. Car has over 500hp and it's driven like it
https://tiresize.com/tiresizes/235-55R17.htm
Curious on your experiences with some of these brands and models. Im in Alaska so pavement here does not get warm and I know that contributes to tire performance.
the problem is age of your tires, did you look at the actual date code on the tire? No reason to go smaller.
Is your Riken Raptors the summer version or the all-season version? I was looking at the average temperature of your area and I would say its marginal regarding temp for true summer only tires. What temperature do you usually drive in?
65 low to as high as 80. Raptor ZR, 300 Treadwear AA Traction A Temp.
UPDATE: found the date code 13th week of 2005! These things look almost new.
akdale (03-18-2019)
While I haven't used the Nitto 555 G2's, they should be good tires based on my experience with Nitto 450's. For a street tire I was quite pleased with them, but I didn't use them at the track much to see their true potential.
I have use Michelin PS2's and those were excellent tires, very sticky, but didn't last too long seeing regular track use. For a performance tire that is nearly 27" tall so they look good on our cars, I would recommend them as an option. Being only 235's, they won't look as aggressive as the Nitto's though.
https://tiresize.com/tires/Michelin/...-235-50R17.htm
Received 3,043 Likes
St. Jude Donor '05
youre lucky they havent come apart....any new tire will feel worlds better.
I would change them and go for some Michelin ones, but I am biased
I always used 255 45 17 fronts. The 50 series would hit the frame on lock to lock with my 4 inch bs
https://m.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel= g-Force+Sport+COMP-2&partnum=545WR7GFSPC2&vehicleSearch=fal se&fromCompare1=yes
