Decode engine 76
Old Mar 19, 2019 | 03:11 PM
Davidinov8's Avatar
Davidinov8
8th Gear
Default Decode engine 76
Hello everyone, surely there will be a discussion like this but I didn't find it,
I want to code the number of my peaks 76 and to know if it is original from factory ...
16s426530 V0304CKX
THANK YOU ALL!
Old Mar 19, 2019 | 03:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
CKX indicates the base L-48 with automatic transmission assembled March 4th at Flint (V0304). #26530 in the VIN derivative should match your full VIN.
Old Mar 19, 2019 | 03:44 PM
Davidinov8's Avatar
Davidinov8
8th Gear
[QUOTE = Easy Mike; 1599072798] CKX indica la base L-48 con cambio automatico assemblato il 4 marzo a Flint (V0304). # 26530 nella derivata VIN dovrebbe corrispondere al VIN completo. [/ QUOTE]
thank Mike, my Vin 1Z37L6S426530!
Old Mar 19, 2019 | 05:40 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Lots of free information here:
https://www.gmheritagecenter.com/gm-...tion-kits.html
Old Mar 21, 2019 | 12:45 AM
aerofix's Avatar
aerofix
Hi Davidinov8, I saw from you other post you just got this car. I couldn’t help but notice when you posted your VIN I thought to myself that is close to my 1976 . My VIN is 1Z37L6S426537. If I understand the numbers correctly mine came off the line sequentially seven after yours. Maybe not sister cars but definitely cousins. Welcome to the forum and best of luck!
Old Mar 21, 2019 | 07:23 AM
Davidinov8's Avatar
Davidinov8
8th Gear
[QUOTE = aerofix; 1599081890] Ciao Davidinov8, ho visto da te altri post che hai appena ricevuto questa macchina. Non ho potuto fare a meno di notare quando hai postato il tuo VIN Ho pensato a me stesso che è vicino al mio 1976. Il mio VIN è 1Z37L6S426537. Se capisco i numeri correttamente, il mio è uscito dalla linea sequenzialmente sette dopo il tuo. Forse non auto sorelle, ma sicuramente cugini. Benvenuti nel forum e buona fortuna! [/CITAZIONE]
Hi aerofix !
fantastic this coincidence, has photos of yours? ... surely the same people in San louis An built in the same work shift!
To Decode engine 76
