Hey guys. When I rebuilt the suspension on my 76 I went with urethane bushings all around. Cut one coil off front for a nicer rake and went with a VB&P 330 # in rear. KYB shocks all around. The top of the front tires are 1/2 inch below fender arch and rear sits 1-1/4 inches higher than front. Just about right.
The rear composite takes approx 60 - 70 pounds off the rear weight and no spare either. My stroker up front with alum heads, water pump, air gap intake and headers shed close to 100 # of cast iron weight. The rear can get a little bouncy with certain road conditions.
Now, I've heard so much about Bilsteins that I am considering a switch to them. First will it noticeably improve the ride?? What combination would be best, front & rear.
Thanks for opinions.
Also, please note that there are 2 different KYP shocks. I originally had the high pressure KYB's (white body) on with a composite rear spring. The rear end was very bouncy and uncontrolled. KYB also makes a low pressure shock that has the option of 2 different valves. One of these is intended for composite springs (with their much lower internal friction damping ) and they work very well at controlling the rear end. They used to be sold by VB&P (no longer in business), but I've seen them lately in other vendor's catalogues.
Royal Canadian Navy
I have almost the exact mods you have stated. I went with QA1's non-adjustable shocks. I don't track my car so the QA1's work great for the street.
Thanks to all for chiming in with your comments. So as far as Bilsteins it sounds like I should consider HD's up front and Sports for the rear. Can someone confirm this for me??
Thanks again.
I'm a few garage sessions away from confirming, but yes, that is what I have. 550 lb fronts, Bilstein HD equivalents; 385 lb composite rear, Bilstein Sports. If it turns out I need sports in the front, too, I'll go with QA1 double adjustable, semi-coilover. The rear is just about right, though.
For your lowered front end, though, there may be an advantage to using Sports.
Thanks again.
Yes..HD's in front with my 550 gymkhana springs and Sports in the rear with the 360 composite spring.
I would stay away from any mass market shock such as KYB's, AC Delcos, Monroes, gabriel...all junk which will give you a soft or mushy ride and will wear out prematurely since they are made to be replaced. I have never had a Bilstein wear out on any of my cars in 30 years......Bilsteins are the best value shock for the money out there...
