Fuel Tank Bung Removal?
Old Mar 20, 2019 | 07:47 PM
Taijutsu's Avatar
Taijutsu
Default Fuel Tank Bung Removal?
Forum: My car is a 74.
Now that I know I'm not getting any fuel from my tank.
I would like to remove the bung and check it before I fill the tank.
It looks like it might be threaded?
Any advice?
TIA
R
Old Mar 20, 2019 | 08:52 PM
DonnieP73's Avatar
DonnieP73
If you are referring to the sending unit, then there is a locking ring that holds it in place.
I used a small chisel to remove my old one, but I would not recommend that. There is a tool for removal and installation of the sending unit.
Donnie
Old Mar 20, 2019 | 08:56 PM
Taijutsu's Avatar
Taijutsu
Default Looks Right
Donnie: Where can I get the proper tool?
I want to finish this and get going.
Anything else I need to know?
R
Old Mar 20, 2019 | 09:00 PM
DonnieP73's Avatar
DonnieP73
I think the vendors here probably sell them. This is what it looks like.
https://www.ebay.com/p/63-74-Corvett...2998163&chn=ps
Hope that helps.
Donnie
Also, there is a o-ring that you might need to replace if yours is flat or not in good shape. You will find it when you remove the unit.
Old Mar 27, 2019 | 12:57 PM
Taijutsu's Avatar
Taijutsu
Default Rear Tire?
How much of the rear tire carrier do I have to remove to get to the sending unit?
TIA
R
Old Mar 27, 2019 | 02:40 PM
carriljc's Avatar
carriljc
Here is the general idea. If you do not get the specific tool, then I suggest using a slightly larger screwdriver. Not much risk, but don't go creating a spark now. If you use some lubricant on the seal it may slide a little easier.
Just get under there and take a look. Drop the spare tire carrier and eyeball it.
TIA
R
Old Mar 27, 2019 | 04:36 PM
Taijutsu's Avatar
Taijutsu
Thanks for the info.
A kind forum member Donnie already pointed me in the right direction for the tool.
Now I have to wait and see what is needed once I pull out the sending unit!
To Fuel Tank Bung Removal?
