Re: This will knock your socks off... (71'AirStrike)
You can get clay bars from Maguire's, Mothers, and even Zaino.
I used soapy water to lubricate the surface, then you just gently slide it around on the surface. It removes the small surface contamination form the paint, leaving a glassy smooth finish when you are done. then wash and rinse throughly, and apply a good layer of wax, and whatever you like to use after.....
This is the first time that i have tried it, and I was impressed.
You can goto the car care section for more information.....
Clay bars work great. It is about the only way to really get your paint clean. Itis amazing to see all that junk coming out of your paint. You just have to be careful you keep the surface well lubricated and you fold in the dirt frequently. They work really well for pulling water spots and buges off your glass too when you wash it :yesnod:
Re: This will knock your socks off... (Desertdawg)
I did mine earlier this year in the spring. Before I did it my paint was not smooth and felt like sandpaper. After doing the first panel I was truly amazed......smooth like glass and helped the shine. I finished my vette....did my Explorer...then did my wifes' Maxima!
