Corrected wiring issues
Old Mar 22, 2019 | 12:52 PM
Kacyc3's Avatar
Kacyc3
Default Corrected wiring issues
Has anyone corrected the wiring of the p/w p/l of these cars? For example the single common ground of the p/l and added an additional ground in the d/s door or completely split the two into separate circuits?.. My p/w are slow and I have one lock that doesnt function, I already have a new lock actuator that needs to be installed. Since I dont like messing with the doors i was thinking about replacing the window motors, installing the new lock actuator, some functional mirrors and addressing the wiring all at the same time, so before I tear the car apart I'd like to build a plan for this process. R&R actuator,test, R&R window motor if this involves removing the window then I can install the mirrors I have planned. Then address the wiring and get full voltage to the window motors.
Old Mar 22, 2019 | 06:27 PM
Richard454's Avatar
Richard454
Here you go-
Just like the headlights- add some relays instead of running the power all over the place (voltage drop) to get to the PW motors-
Old Mar 20, 2020 | 07:11 PM
Kacyc3's Avatar
Kacyc3
Originally Posted by Richard454
Here you go-
Bringing this back up as I may get this done if work gets shut down, any idea why it shows using two SPDT relays per window instead of a SPST?
Old Mar 20, 2020 | 10:06 PM
Richard454's Avatar
Richard454
HA- that what I had when I drew it up a while back on my laptop...
To Corrected wiring issues
