Best Oil Filter for the Money?
#81
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Where are all these 'chunks' of metal coming from? Cheaply made parts? Really? Even if some particulate passes through the filter, is it going to do damage to the engine? 30um is pretty darn small and will probably get imbedded in the babbit of the journal bearing which is designed to do this. Or get filtered on the next pass or settle on the bottom of the base pan. No need to over think this stuff. Again, I've used Fram filters for over 40 years more often than not. I too have a lot of money in my engine and there's a Fram oil filter installed and a K&N air filter. I ain't losing any sleep over it.
#82
Technically, the filter only flows at the rate oil leaks from the crank bearings and through the valvetrain. Generally speaking, putting a higher flowing filter onto your engine won't result in more oil flow through the engine.
I had a 350 which had the bypass plugged and a HVHP pump with a standard pressure spring. I ran both car and truck size filters on it and the oil pressure stayed right at 60psi all the time while driving at any rpm above idle. The oil filter size made no difference on oil pressure.
Double Bingo.
I think the clean engine is more a function of the additive package of the oil rather than the filtration of any filter used. Mobil one has a very good cleaning additive package in their oil. Oils of years gone by did not have particularly good cleaning capabilities nor were they very good at keeping contaminates in suspension in the oil.
#83
50,000 miles?
Remove two zeros and watch the videos on YouTube about filter internals.
Some of you may remember a Fram commercial shown on TV years ago. It was about a mechanic wiping his hands with a towel and holding a orange filter.
At that time their slogan was:
"You can pay me now or you can pay me later'". Meaning that if you don't use Fram then you will pay the mechanic for repairs later.
Now that I am older and wiser I realize that slogan really means that if you install a Fram, you will pay for repairs later.
Do you have some proof that the Fram XG filters have construction issues or is this just based on an unfounded bias against everything the company makes?
I'm interesting in seeing proof, but the other is completely useless.
#85
I've used truck oil filters in drag boats and classic cars for years.
It wasn't about more surface area or even filtration, it was just to have an extra 1/2 quart oil capacity in the system.
They can be a bear to get around some headers, but if you punch a pin hole in the upper part of the filter and one at the bottom, then let the oil drip into a pan overnight, you can spin the filter off and maneuver it through the header without making any mess.
WIX and Napa Gold filters have always been my preferred choices.
Back in the day when I was a high school kid, I worked in a full service gas station at night for extra money.
Does anyone here remember the old canister oil filters that were OEM on some american made cars?
It was not uncommon to do an oil change, drop the canister and find someone was using a roll of toilet paper for filtering the oil.
#86
I had a Frantz toilet paper bypass filter on an 81 cj5 with a 304 ci motor when changing the just the toilet paper filter after about 100 miles the oil would be noticeably cleaner and when pulling the filter out it was jet black. I always thought it caught very fine partials. I had 250000 miles on that engine when i sold it and never an oil related problem and it used about 1/2 quart in 3000 miles between oil changes. And if i remember right it called for the cheapest roll of white toilet paper you could find and at that time 1 roll was $0.15 at the store could not beet the price for a filter change.
Maybe they actually worked better than the oil filters produced today so the manufactures were biased and kept them out of the testing.
LOL
#87
Received 2,127 Likes
Use what filter you want. No cardboard and cheap spring for me.
#88
Adam
amandico82 (03-27-2021)
#91
Then there is this. Pure Power cleanable unit with rare earth magnet.
#92
I could care less what you've seen about their low end product line so don't bother with links showing them. It's been well established that they are junk. But the XG filter is rather well regarded in any circle that isn't blindly biased against the company.
#93
This is what the original motor above, looked like seven years ago! All we did was swap heads and put a cam in it. The bottom end was untouched. We pulled the main caps, checked the crank bearings and put it together and back in, exactly as is. The care I applied to it, actually cleaned the entire inside of the engine!
#95
OK, post these links showing how crappy the XG filter model is.
That said, is there a Wix XP filter that will fit? They don't seem to make a 51069XP.
Here's a video. The Fram XG seems to be equivalent to the Wix XP.
For those of you wanting a deal on filters, RockAuto has Ultra-Power 51069 filters for about $1- each. These are likely the bottom of the line Fram filters, packaged for CarQuest, and sold on clearance.
#96
Trucker in town would stuff the oil filter housing with feminine napkins because they were cheaper at the time than oil filter elements. He died with a fistful of dollars. We called him Easy Ed.
#97
my dad when i was a little boy he had a Ford Commit and he would put a roll of toilet paper in a filter housing and take the old one out and put it in the trash every oil change.. I remember him showing me how to change oil on tis car.. I was maybe 5??
I miss him:-(
#98
