turn signal switch
Old Mar 26, 2019 | 10:12 PM
martys76's Avatar
martys76
Default turn signal switch
is there a difference between not tilt and tilt signal switch i have a 76
ad it gets confusing on what to order i have tilt and tellie
Old Mar 27, 2019 | 11:07 AM
kansas123's Avatar
kansas123
I believe that there is. I looked at one vendor's site and there are two seperate listings, one with TT & Tel, and one without.
Old Mar 27, 2019 | 05:57 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Yes there is go to lectric limited they will get you the right one.
Old Jan 26, 2020 | 06:35 PM
Renwaltoys's Avatar
Renwaltoys
It is a 1965 car.
Old Jan 26, 2020 | 11:47 PM
Eliredandblack's Avatar
Eliredandblack
Changing the switch in the steering column is not very pleasant. Use Willcox’s step by step procedure and you won’t have any trouble. They have instructions on making a screw in device that keeps the tele locked so you can pull the hub off. I bought a steering wheel puller at HF. With my horn issues and painting the column pates, I have used the wheel puller many times.
Good Luck
To turn signal switch
