Carburetor gasket
If you are talking about the gasket between the carburetor and intake manifold, the gasket thickness has no effect on performance. Spacers on a modified car can change the performance characteristics depending on the carburetor and type of intake manifold.
Most use a 1/4" thick in four hole or open.....to insulate heat. The open spacer will flow a tad better upstairs and I believe is what the L-82 came with.
https://quadrajetparts.com/advanced_..._description=1
Jebby
Jebby
