Muncie 4 speed rebuild
Old Mar 30, 2019 | 10:31 AM
Bhebert449's Avatar
Bhebert449
Default Muncie 4 speed rebuild
Anyone know of a reputable place I can ship my m21 Muncie off my 69 for a rebuild. Unfortunately I have not found anyone local that I trust. I am thinking I will remove it myself and ship it somewhere for a rebuild. I am in Beaumont TX which is 90 miles east of Houston.
Reason for rebuild is it slips out of gear on deceleration and I hear a whine in second gear. Everything I have was tells me it sounds like synchronizes are worn.
Old Mar 30, 2019 | 12:20 PM
jb78L-82's Avatar
jb78L-82
I would speak with Gary Ramadei...GTR1999 on this forum
Old Mar 30, 2019 | 12:42 PM
righthanddrive's Avatar
righthanddrive
Does it grind going into 2nd ? It could be your shift rods aren't aligned , or your shifter is worn..
Old Mar 30, 2019 | 12:55 PM
Bhebert449's Avatar
Bhebert449
it doesn’t grind going into 2nd. I would like to try easy stuff first.
Old Mar 30, 2019 | 09:53 PM
Wee's Avatar
Wee
Paul at 5speeds.com
Brian
Old Mar 31, 2019 | 07:58 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If it pops out of second on decel its usually the synchro slider not holding anymore. Paul at 5speeds is your best bet. You can look up his how to videos on youtube. I rebuilt mine with his videos and how to books. Its really easy. His vids are the best. I bought my parts from him ( http://www.5speeds.com/cart/index.ph...5_17_69&page=3 ) and from the gearbox http://www.thegearbox.org/Muncie.html
They make some really good speed parts for muncies now that make them even easier to rebuild like caged bearings and bolt in cluster pins and grooved bearing sleeves. You can even buy everything to upgrade your M20/21 to a M22 or just buy them rebuilt for $2000. I rebuilt mine with all new everything except the main shaft for about $1000
Old Mar 31, 2019 | 08:32 AM
Tampa Jerry's Avatar
Tampa Jerry
Try posting on the C-2 section for a greater response. There are a lot of Muncie equipped cars as most members have stick shifts. Jerry
Old Apr 1, 2019 | 11:06 PM
1974ta's Avatar
1974ta
I used Jodi's Transmissions in PA for my 70 M20. Now it shifts perfectly through all the gears. Great guy. Lots and lots of experience.
Kind Regards,
Bill
Old Apr 2, 2019 | 07:48 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Ed Hartnett out of Philadelphia will do a great job for youif you don’t mind shipping.
Old Apr 2, 2019 | 08:18 AM
Scottd's Avatar
Scottd
Before you go chasing synchros and start gutting your transmission, check the cover. The 'door' that the shift linkage goes thru. The legs on the inside get worn and will make you pop out of gear on decel.
I had my transmission out twice over a 4 month period, diagnosing the same problem. Every time Id let off the gas, the shifter would just pop into neutral. I replaced synchros, gears and the main shaft. After the 2nd rebuild I took the car to a guy who knew old Muncies (took me a while to find somebody) and he immediately replaced the cover. Problem solved, lots of money wasted, but I learned how to tear apart and rebuild a Muncie.
Old Apr 2, 2019 | 01:44 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Jody's transmissions or Paul C @ 5speeds.com are who I would use. I have bought parts from both and they are great to deal with.
To Muncie 4 speed rebuild
