setting body back on frame
Mar 31, 2019 | 10:58 AM
the body goes back on the frame level right?
im finally setting the body back on and the front goes right back on the rocker channels are kind of tight
and the rear body is 6'' above the rear body mounts
I used a forklift and straps at the back of the doors and inbetween the front fender and the door,with u-plates on the rocker lip
anybody else have problems like this?
Apr 1, 2019 | 04:15 AM
Okay, what year car are you working on, and take the time for a few pictures so we can see with you are dealing with.
RVZIO
Apr 1, 2019 | 07:07 AM
Cruise-In II Veteran
Quote:
Originally Posted by
dmaxx3500
...the rear body is 6'' above the rear body mounts...
You've got something keeping the rear in the air.
Apr 1, 2019 | 08:14 AM
1969 conv
and it seems to be in the middle around the tranny
im pulling the body off tomorrow [with a forklift]
cars up high enough ,for me to slide under and run my hands almost everywhere,and ive got clearance
ive put car [steel],truck bodys and beds back on ,and never had this problem
Apr 1, 2019 | 11:11 AM
Was the body supported while off? Do door gaps look ok? PM allvettesforme. He will know top of his head how much higher or lower mounts 1-4 should be.
Apr 1, 2019 | 12:20 PM
I just got off the phone with a corvette restorer in my area,,his idea was to start pulling the body down to the frame , [sounds scary to me
body was on a dolly,supported under the #2-#3 body mounts,using 2x8's on end [should have spread out the weight]
im going to lift the body this week with the neighbors forklift and body straps,
something's just not right
Apr 2, 2019 | 05:31 PM
update
body fits just fine
after getting the LR wheel opening rear filler off the #4 body mount
now to shim it,but, gaps are pretty good right now
thanks for the help guys
