VACUUM FITTINGS
Old Nov 3, 2002 | 08:18 PM
Oldguard 7's Avatar
Oldguard 7
Default VACUUM FITTINGS
For those of you who use the Edebrock 2101 manifold. Where do you get the vacuum hose fittings which sit atop the manifold. Any suggestions? :confused:
Old Nov 3, 2002 | 09:12 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: VACUUM FITTINGS (Oldguard 7)
Do you mean the fitting for the brake booster hose and other accessories that is on the rear of the manifold? Edelbrock makes a low profile fitting, but if you are using a Holley carb like I am it isn't low enough, and it won't screw into the correct position which means you'll have to grind the top of it off a bit. I did see a nice one which had 3 fittings coming off it on the sides made for this situation but the web site listed was only a main page and nothing else. The company was called Mo' Speed, haven't tried to call them yet but I really should.
Old Nov 4, 2002 | 10:16 AM
Oldguard 7's Avatar
Oldguard 7
Default Re: VACUUM FITTINGS (C3 Shark Tank)
yup thats the one. Im using an Edelbrock carb.
To VACUUM FITTINGS
